Changing spark plug wires: E320 - Mercedes-Benz Forum
post #1 of 6 (permalink) Old 01-19-2010, 07:36 PM Thread Starter
Date registered: Jan 2010
How hard is it to change the spark plug wires on a 2002 E320 4matic? I'm thinking of doing it myself. Dealer told me I have cylinders misfiring due to bad wires. They want to change all the wires (12) and also change the spark plugs (12). Car has 70,000 miles. I'm going to wait til 100,000 miles for the plugs but will change out the wires. Any help on how to do it. Seems like it should be very simple.
Thanks!
ScarletDog is offline
post #2 of 6 (permalink) Old 01-20-2010, 04:33 AM
Michael Pillay's Avatar
Date registered: Oct 2003
Quoted: 91 Post(s)
I believe that is a M112 engine and the same as in my 2002 ML320. If I am not wrong, someone will correct me, I am sure! But if this is the case, changing the wires is simple. You might want to consider changing the plugs since you will be in the middle of it anyway. I would also do a search of the w210 forum so see if someone has already done a write up on how to do it.
If you intend to change the wires, a 17 mm open end wrench comes in handy to pop the boot of the plug. Other than that it is pretty straight forward. AutohausAZ should have the wires.
Mike
Michael Pillay is offline
post #3 of 6 (permalink) Old 01-20-2010, 04:50 AM
eric242340's Avatar
Quoted: 311 Post(s)
^^Correct thus far. I would strongly recommend changing the plugs at the same time because the bad HT cables will have caused uneven burn and hence damage to the plugs.
New cables + old plugs could mean more misfires and possible damage to new cables as a result. The dealers were trying to cover themselves against this possibility but it is now up to the OP.
ERIC.
eric242340 is online now
post #4 of 6 (permalink) Old 01-20-2010, 11:12 AM
Date registered: May 2005
Vehicle: '07 GL320CDI
Quoted: 2 Post(s)
The "official" Mercedes procedure is to change wires individually as required.
The wires are about $35 each at a dealer, so 12 X 35 = $420.
This is not a POS 'merikun car where every service is a "why don't we do this?" scam.
OE wires are pryed off the plugs using a 17mm wrench, i.e. they don't just pull off.
Kent Christensen
Albuquerque
'07 GL320CDI
lkchris is offline
post #5 of 6 (permalink) Old 01-22-2010, 08:41 PM
Date registered: Jan 2004
Quoted: 34 Post(s)
I think the plug service is 100,000 miles OR five years, so you are due. I'd only change the plugs (use the correct plug) and see what that does. Wires last a long time usually.
Len
'59 220S Cabriolet - for sale - http://www.bruceadams190sl.com/1959-...20s-cabriolet/
'83 240D original owner 351,500 miles - sadly I let it go
'88 560SL 41,000 miles being parted out - https://sites.google.com/site/mercedesstuff/home
'99 E300 turbo 207,000 miles
'03 SLK320 37,500 miles
'14 Smart electric 10,500 miles
sokoloff is offline
post #6 of 6 (permalink) Old 01-22-2010, 08:44 PM
eric242340's Avatar
Quoted: 311 Post(s)
On these engines, the wires are not a common problem but when they go wrong it is normally more than one that goes.
ERIC.
Spark Plug Wires mercedesmonk W202 C-Class 11 03-11-2011 07:15 PM
Spark plug wires JAD W163 M-Class 10 04-07-2008 10:49 PM
Spark plug wires / Ignition Wires DETANE W163 M-Class 11 04-24-2007 05:29 AM
Changing Spark Plug Wires..... orlandotrader W163 M-Class 0 11-10-2005 06:14 AM
Spark plug wires.. How much? orlandotrader W163 M-Class 5 10-13-2005 12:52 PM
