Wheel not centered - Mercedes-Benz Forum
post #1 of 5 (permalink) Old 01-17-2010, 11:56 PM Thread Starter
npk
Date registered: May 2005
Vehicle: W123, W116 Wagon
Wheel not centered
New bearings and rim/wheel not bent or deformed. However the rear left wheel (of my W123) does not rotate center.
I marked a point at the dust cover(at 6 o-clock), turn the wheel, the gap between the dust cover(at 6 o'clock) and the rim varies.
Initially I thought were the wheel bearing or rim. Got the bearing changed and wheel checked.
Could the brake disc or hub cause this problem?
Thanks in advance.
NPK
npk is offline
post #2 of 5 (permalink) Old 01-18-2010, 09:21 AM
Kajtek1's Avatar
Quoted: 1223 Post(s)
Could be bent axle.
Did you do the test with different wheel?
The tire could have imperfection as well.
Kajtek1 is offline
post #3 of 5 (permalink) Old 01-19-2010, 09:03 AM
Supporting Vendor
FCP Euro's Avatar
Date registered: Jul 2008
Quoted: 23 Post(s)
Try putting one of your other wheels on that axle as see if it does the same thing. If it does, then it is an issue with the axle of the suspension. If not, then the rim and/or tire is bad.
Let us know how you make out.
Quality & Service, Guaranteed for Life
FCP Euro - OEM & Genuine European Auto Parts Online
FCP Euro is offline
post #4 of 5 (permalink) Old 01-19-2010, 06:46 PM
Date registered: Aug 2008
Vehicle: 2008 E320 Bluetec, 1988 560SL totalled unto death). 1997 Dodge Ram 1500, 1983 300CD
Quoted: 177 Post(s)
eccentricity
MB wheels are hub centered unlike many others that rely on lug bolt seats for centering.
Was the wheel seated firmly on the hub before tightening lugs?
Are the lugs torqued evenly?
Is this a new wheel using aftermarket lugs? They must be the right length and flat or taper seated depending on the application.
rocky raccoon is offline
post #5 of 5 (permalink) Old 01-19-2010, 10:12 PM
Diesel Benz's Avatar
Quoted: 37 Post(s)
Considering aftermarket wheels, I once had those for a Volvo with a centre hub (size) adapter that I forgot to install. Even if the car had conical lugs, the wheels were badly centred. Amazing how much the wheel can be off-centre when just centred by bolts.
But most MB aftermarket wheels come with the correct centre hub.
Diesel Benz is offline
    Center console not centered lifewithoutpain W126 S,SE,SEC,SEL,SD,SDL Class 6 08-11-2009 10:54 AM
    Replaced Lower Control Arm Bushings - Steering Wheel not Centered? PatOpsahl W210 E-Class 8 08-23-2008 11:18 AM
    Back wheels not centered Heav-e-d W201 190-Class 5 12-31-2006 05:57 PM
    Off centered Steering Wheel or Alginment kchendds W211 E55 AMG, E63 AMG 0 05-07-2004 05:59 PM
    steering wheel-slightly off centered.... Guest (MBNZ) W203 C-Class 1 01-12-2002 06:08 PM
