Screw and bolt broke on my battery, need help finding more - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 01-16-2010, 09:10 PM Thread Starter
Date registered: Feb 2009
I have a mercedes ML 320 2001 6 cylinder. After checking the battery for my six hour long trek back to college for Spring semester both screws on the batter + and - indicators broke. They seemed very corroded. Anyways, I am planning to leave except I can't go till I get this one bolt. It is a square head that says either PBS or FBS on the head. On the bottom it says 5.8. Does anyone know where I can get a replacement? I've gone to lowes and three autozones and a pep boys and no one can find them :./
Deganveran is offline
post #2 of 4 (permalink) Old 01-16-2010, 11:25 PM
Diesel Benz's Avatar
Quoted: 37 Post(s)
So you mean the screw from the connector to the battery pole? Can't you use a bolt from a connector that you can buy separately or just any other bolt at least temporarily? If it needs to be square (only allows a single tool to be used) you could tool a hex nut/bolt to fit.
Diesel Benz is offline
post #3 of 4 (permalink) Old 01-17-2010, 04:47 AM
Date registered: Aug 2008
Vehicle: 2008 E320 Bluetec, 1988 560SL totalled unto death). 1997 Dodge Ram 1500, 1983 300CD
Quoted: 177 Post(s)
Any bolt
Any bolt that fits will be fine. As previously mentioned, the square head is a convenience (and a minor safety feature) that allows the use of one wrench to loosen/remove the nut.
The corrosion should be of more concern. I would recommend removing the battery to look for corrosion beneath it, then washing the battery compartment and the battery if necessary with a thick, almost paste baking soda solution to neutralize the leaking battery acid and vapor. A coat of Rustoleum in the battery compartment may be needed. Also, check to ensure your battery vent tube is in place. If not, make it so.
Go back to your Pep Boys for a pair of those red and green felt collars to go under your battery cables to prevent future problems.
rocky raccoon is offline
post #4 of 4 (permalink) Old 01-17-2010, 09:54 PM Thread Starter
Thanks everyone who answered. It was a hard fit but I got a angled bolt wrench to tighten it. Thanks again.
    valve cover bolt screw up neosama W123 E,CE,D,CD,TD,TE Class 5 01-27-2010 09:04 PM
    DAMN! Distributor cap screw broke! NoPrayer W201 190-Class 5 11-02-2009 10:10 AM
    Getting Out A Screw That Broke MimoG3 W201 190-Class 5 07-25-2009 06:12 PM
    Oh Crap....Broke the bolt off Big"D"inTheMB W210 E-Class 2 03-12-2008 01:32 PM
    Brake pad torx screw/bolt size joeml W163 M-Class 0 09-18-2005 04:35 PM
