C280 w202 Ignition park lock cable - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 01-14-2010, 05:04 AM Thread Starter
Date registered: Jan 2010
Vehicle: 1994 C280
Hi all ....this is my first post...sorry it has to be a call for help
I have just had the dreaded "key won't turn in the ignition" saga which ended in the use of a power tool to remove the ignition
I have now put in the new (well new to me ) ignition and attached the park lock cable and the car started fine but wont come out of park. If I remove the cable from the ignition and operate the cable with my thumb it works & the stick will come out of park but not when the cable is screwed into the ignition.
Am I missing something here??
I am hoping that some one far more knowledgeable than me has a solution & I thank you all kindly for taking the time to read my post.
Davefnq is offline
post #2 of 3 (permalink) Old 01-14-2010, 07:39 AM
keyhole's Avatar
Date registered: Sep 2006
Vehicle: 2004 CLK 240 Coupe
Quoted: 381 Post(s)
Dave: I have no special knowledge here... just a WIS on DVD. But I noted the following when looking up your W202. Does this sound familiar?
Perhaps you need to adjust the shift lock gap (A) to 0.2mm as described below.
Remedies for electronic ignition switch (EIS) malfunctions.
Problem:
Key inserted in electronic switch (EIS) can be turned between positions 1 and 3; however cannot be removed and engine cannot be started.
Cause 11:
Defective shift lock adjustment on vehicles with automatic transmission.
Remedy 11:
1. Check shift lock. If not OK -
2. Adjust shift lock.
Name:	W202 shift lock 1.jpg
ID:	284750   Click image for larger version
Name:	W202 shift lock 2.jpg
keyhole is offline
post #3 of 3 (permalink) Old 01-15-2010, 05:56 PM Thread Starter
Vehicle: 1994 C280
Thanks for that Keyhole.....though not sure if that is the problem as those are not the symptoms I am experiencing but I will check out the adjustment none the less. Will let you know how I went & if anybody else has any other suggestions feel free to suggest away
Davefnq is offline
    Steering lock stuck on? Or ignition lock?.....help! busters the boy! W124 E,CE,D,TD Class 21 05-12-2013 09:09 PM
    Help!! Park Lock Override? MichaelSFletcher W202 C-Class 0 11-06-2008 07:26 AM
    ignition lock cylinder & ignition switch lakeside W164 M-Class 2 07-23-2007 06:55 PM
    Park brake cable breaks W124 1989 300E benzdriver737 W124 E,CE,D,TD Class 0 10-17-2005 01:36 AM
    Park brake cable breaks benzdriver737 W124 E,CE,D,TD Class 0 10-17-2005 01:28 AM
