Will these rims fit my C-class? - Mercedes-Benz Forum
post #1 of 18 (permalink) Old 01-13-2010, 10:05 PM Thread Starter
Deutschstolz777's Avatar
Date registered: Jan 2010
Vehicle: 2001 Mercedes Benz C240
I drive a 2001 C 240 and i was wondering if these would fit.
Bolt Pattern(s) (millimeters):5x112
Rim Width: 9"
Rim Diameter (inches): 19
Offset: 40
Deutschstolz777 is offline
post #2 of 18 (permalink) Old 01-14-2010, 11:03 AM Thread Starter
bump
post #3 of 18 (permalink) Old 01-14-2010, 04:18 PM
Date registered: May 2005
Vehicle: '07 GL320CDI
Quoted: 2 Post(s)
Remember that Mercedes uses lug bolts and not lug nuts, so if these are aftermarket items different bolts may be required, too. Best bet is to ask the manufacturer of the wheels.
Kent Christensen
Albuquerque
'07 GL320CDI
lkchris is offline
post #4 of 18 (permalink) Old 01-14-2010, 07:37 PM Thread Starter
The rims are currently on a CLS. The only problem i can see is that they're 9" wide. Do you know if those are to wide to fit on a smaller C240?
post #5 of 18 (permalink) Old 01-14-2010, 08:22 PM
lowbox68's Avatar
Date registered: Nov 2009
Vehicle: 2003 C240
good luck . I asked almost the same question here almost 6 weeks ago and never got a answer. I have a 2003 C240 and want to run 18x8.5 in the front and 18x9.5 outback ????
lowbox68 is offline
post #6 of 18 (permalink) Old 01-14-2010, 10:31 PM
Date registered: Jun 2009
Vehicle: 1991 300E
Basic answer is any wheel will fit any car if it's important enough to you. There are many, many examples of that on this site and others. Tirerack.com suggests that you may need to roll the fenders if you want to run the 19" wheels. They consider this a "very aggressive fitment."
300E91 is offline
post #7 of 18 (permalink) Old 01-15-2010, 04:14 AM
lowbox68's Avatar
Vehicle: 2003 C240
300E91
Vehicle: 1991 300E
Posts: 64 wheel size help code kba42359
I've got a banged up rim on my 1991 300e and a spare on a non-matching rim. I'm looking for a replacement rim, but cant determine the correct, matching offset.
I've searched here and elsewhere and find that my year and model could have one of three offsets, 44, 48, 49. I'm running 195/65R/15.
The only code I see is on the outside of the rim and it's KBA42359. They are 8 hole alloy.
Thanks Hmmmm you seem to have learned a lot in 5 months , or not . Any wheel will fit any car . So that means I can put a 18x12.5 rim with a 0 offset all the way around my car and I just have to roll the fender lips a little.
lowbox68 is offline
post #8 of 18 (permalink) Old 01-15-2010, 06:27 AM
S.A.T's Avatar
Vehicle: SL 500 AMG, Porsche Panorama turbo, Bentely GT, Escalade, Ferrari F360 Spider
Mercedes c class's use 5x112 bolt pattern, they are high offset which will be between 35-42. So these wheels will fit. Rim width is should be ok too
Authorized Lorinser Dealer
www.shopsat.com
Specialty Automotive Treatments
700 W Sunrise Blvd.
Fort Lauderdale, Fl 33311
(954) 728-1234
Cristina@satreatments.com
S.A.T is offline
post #9 of 18 (permalink) Old 01-15-2010, 10:48 AM
Vehicle: 1991 300E
Originally Posted by lowbox68 View Post
300E91
Yes, I have learned a fair bit in 5 months and take the time to educate myself when possible. If you took the time to do a search of this site you would find many examples of non-standard wheels fitted to various cars, including C240. Yes, offset can be an issue, but time, money and persistence can solve anything.
Many folks on this site have tired of wheel size questions because it often devolves into foolishness. Your response is a good example of this. It is surprising to me that you took the time to open my profile, but couldn't take the time to do a search and answer your own question. It will be interesting to see how your stature develops on this board.
300E91 is offline
post #10 of 18 (permalink) Old 01-15-2010, 05:49 PM
lowbox68's Avatar
Vehicle: 2003 C240
I did do a search and did not find anything. Maybe you should do a search for me and post the results . As for stature, you make it sound like some kind of prick waving battle. But I am not waving my prick, I just want INTELLIGENT info on wheels from someone who has done it .
lowbox68 is offline
Will stock 99 S-class 16" rims fit on 96 E-class?? gradyg3 W210 E-Class 30 01-16-2010 06:26 PM
Do E class amg rims fit on an S class??? Benz915 W220 S-Class 1 04-21-2009 09:35 AM
02 S Class Rims fit W210? DominicArnold W210 E-Class 8 06-08-2007 01:38 PM
s class rims fit on a c230? DnBtekhnic W203 C-Class 3 02-06-2007 05:27 PM
Will the 210 (97 E-Class) 16" and the 203 (01 C-Class) 15" rims fit the 201 (87 190E - 16V)? Guest (MBNZ) The Discount Tire Direct Tire, Wheel, Brake & Suspension 0 09-11-2001 06:14 PM
