2010 GL450 Purge valve - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 01-13-2010, 11:04 AM Thread Starter
Date registered: Jan 2010
Just bought my 2010 GL450 2 wks ago with only 400 miles in it. A bit disappointed because CEL came on las night while driving; called roadside assistance, gas cap was mentioned as cause, recommended to retighten it and CEL will disappear it 6-8 hours. The following morning CEL is still on, took it to dealer, and this was its findings: Mechanical Fault PUrge valve; TC found P2421 mechanical fault Y58/1, noted purge control valve was permanently open. Solution: guided test, remove hoses, replaced valve, cleared DTC, evap test passed.
I asked service advisor what has caused this:
--- not loose gas cap
--- faulty purge valve from factory
Now i am wondering given this brand, quality control shld be at best; and for something to fail this early...
Anybody out there has experienced this?
I hope this will only be the problem with my car from hereon, at least for several thousand miles...
thanks for your input.
moncad is offline
post #2 of 4 (permalink) Old 01-13-2010, 11:56 AM
Date registered: Dec 2009
Vehicle: 2006 c280, 2009 320 ML BT, 2011 ML 550 Grand Edition
Send a message via Skype™ to morbid angel
I wouldn't worry about it. Your car has 4 years factory warranty. Typically if it breaks down too many times they will just buy it back from you. With that said though you should double check this with your MB dealer.
morbid angel is offline
post #3 of 4 (permalink) Old 01-13-2010, 12:49 PM Thread Starter
Morbid Angel: thanks for your response. Hopefully, no troubles for now
moncad is offline
post #4 of 4 (permalink) Old 01-13-2010, 10:15 PM
leapyfish's Avatar
Date registered: Apr 2008
Vehicle: 1998 SLK230 199,xxx Miles
Quoted: 4 Post(s)
leapyfish is offline
    2010 GL450 Running Boards Greg 560 X164 GL-Class 1 01-12-2010 09:09 PM
    I'm a new owner of a 2010 GL450 and new to MB claytonvegas General Mercedes-Benz 2 11-16-2009 11:04 AM
    Purge valve dlbehrns C208/A208 CLK-Class 2 10-04-2008 04:27 PM
    Purge Valve guardgrey51 R170 SLK-Class 1 08-04-2007 11:35 AM
    What is a purge valve? Guest (MBNZ) W203 C-Class 2 11-06-2001 01:17 AM
