ML320 ABS light on, looses acceleration when hits bumps on the road... HELP ! - Mercedes-Benz Forum
post #1 of 1 (permalink) Old 01-10-2010, 02:54 PM Thread Starter
Date registered: Jan 2010
Post ML320 ABS light on, looses acceleration when hits bumps on the road... HELP !
I have my Mercedes Benz SUV 2000 ML320; Each time while driving, it hits a small bump on the road, the ABS light comes on and the vehicle looses it's acceleration and I have to drive to the side and shut the vehicle off for a few seconds to minutes. When the vehicle it's started after, it runs as normal, yet again each time it hits a small bump on a road or even on the highway it drops it's accelerator, I can't accelerate the vehicle further, just pull over and shut the vehicle off and wait, as if doing a reset. Note: one thing I do notice is that when the issue is in effect as I pull over and stop and put the vehicle in parking, the idle is very low and it is not an even idle, it's more like and swaying up and down idle. My conclusion was something that has to do with the "ABS WHEEL SPEED SENSORS"... Could I be accurate on this, before I go into further expenses without being sure of the actual problem... Please help with this ongoing long going issue... Thank you in advance ! Douglas
*** Having the "Check Engine" lit, the codes displayed for my Mercedes Benz ML320 year 2000 are: P1580 Malfunction Control Vehicle Speed, Idle Speed Control, Auxiliary Inputs.
Also displayed on the ACTRON are codes: P0170 (Fuel Trim Malfunction Bank 1)and P0173 (Fuel Trim Malfunction; Bank 2) PLEASE HELP !!!
Deloreanpr007 is offline
    ML320 ABS, ETS and parking brake light on With beeping USCMBZ W163 M-Class 13 04-27-2016 07:46 PM
    ABS Light when i Hit Bumps 90-500SL R129 SL-Class 2 05-05-2006 11:16 PM
    ABS & ETS Light On on ML320 carreagt1990 W163 M-Class 1 03-14-2005 02:33 PM
    2001 ML320 Stalls at bumps in the road? dyi General Mercedes-Benz 0 03-09-2005 12:30 AM
