LCD dropout and cylinder firing problem on W202 - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 01-08-2010, 07:36 AM Thread Starter
Date registered: Dec 2009
On my Mercedes Benz C180 (1997-model) the LCD panel for outside temperature, odometer and clock (bottom instruments) has started to disappear during rides. The only way to make them reappear is to stop and start the engine. About the same time this started happening, the engine started to have problems. The engine suddenly lose almost all power, and it gets a rough idle. Restarting the engine fixes the problem.
I suspect that these two problems are related, because they once occured at exactly the same time. The problem usually happen once every ride (10 km), but seems pretty random.
Just got back from the car shop, and they told me the engine computer reported that there had been a misfiring on cylinder #4. They did not find the cause of the problem, but suspected that is was an electrical fault. They told me the problem could be difficult to diagnose. I got the car back for the weekend to see if their fiddeling had solved anything. The problem reappeared on my way home from the shop.
It is pretty cold up here in Norway at the moment (below 20 degrees celsius), but the car has worked fine at this temperature for the last 13 years.
Has anyone experienced similar problems? Any tips?
Thanks in advance! -Baard
baard is offline
post #2 of 2 (permalink) Old 01-08-2010, 08:04 AM Thread Starter
Moved to the W202 forum. Sorry!
baard is offline
    Cylinder 2 and 4 miss firing azatrum W203 C-Class 7 04-22-2009 07:57 AM
    Cylinder 8 not firing properly bluefang R/C107 SL/SLC Class 12 12-14-2008 07:42 AM
    One cylinder of 8 not firing Kay1 W126 S,SE,SEC,SEL,SD,SDL Class 1 03-04-2007 08:03 AM
    87 420sel cylinder not firing? johnwinkel W126 S,SE,SEC,SEL,SD,SDL Class 8 10-21-2006 11:24 AM
    Cylinder 2&3 not firing uzitron W202 C-Class 2 09-13-2006 05:52 AM
