Fuel injection problem for Benz 300E - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 01-07-2010, 03:20 PM Thread Starter
jtwhr's Avatar
Date registered: Jan 2010
Vehicle: Mercedes Benz 300E
Send a message via MSN to jtwhr
Hi--I'm new to the site, this is a similar site to celicasupra. I just bought an '88 Mercedes Benz 300E. It has 215,000 km on it. I have always wanted to be an owner of a Mercedes Benz, so when I seen this, I could not pass it up. I am having a couple of issues with it right now. Being that it is mechanical fuel injection, it was running--I added gas to it, and it just died. I cannot get it started. I have a power drain to my battery, but first things first--with this mechanical fuel injection, do I bleed the fuel system if there is an airlock? Has anyone had similar problems with these inline 6 in the 300E? The wiring issue should not be hard to figure out, but I am kind of stumped on why it just stalled. I have not had to much experience with these mechanic fuel injections--any kind of info or any kind of direction that someone could point me too would be very appreciated. What is the size of our wheels in mm.
jtwhr is offline
post #2 of 4 (permalink) Old 01-07-2010, 05:16 PM
Kajtek1's Avatar
Quoted: 1223 Post(s)
welcome to the forum. It's been long time since I own car with mechanical FI, but I still remember how sensitive the system was to bad fuel.
Your problem started after fill up, what raise the red flag.
Go to proper model section for experience from the same model owners.
Kajtek1 is online now
post #3 of 4 (permalink) Old 01-11-2010, 11:48 PM
Date registered: Apr 2009
Vehicle: Current: 1987 560 SEC US, former factory trained MB tech 10 years, owner of 14 others.
It is CIS, not mechanical. It is self-bleeding. Check to see if your fuel pump is on when you try to start it. It is possible there is a relationsip between your voltage drain and your lack of starting. Check all your fuses first of all.
renaissance_warrior is offline
post #4 of 4 (permalink) Old 01-12-2010, 02:53 AM
Benz in Brazil's Avatar
Date registered: Jul 2008
Vehicle: 1976 W116 - 280S / 1994 W140 - S320
My 300E doesn't start if the battery is low on charge. I left the car in a bodyshop to have some scratches painted over and they couldn't get the car to start after being stationary two weeks. Once the battery was on full charge, she started up no problem. I believe the fuel injection system is actually electro-mechanical so it may have something to do with it but, do look at the fuses (remove and clean) and relays too.
Benz in Brazil is offline
    124 230TE fuel injection problem drchatha W124 E,CE,D,TD Class 0 12-23-2008 04:26 AM
    Fuel injection problem? Benzzy280 W123 E,CE,D,CD,TD,TE Class 4 02-23-2008 05:45 AM
    Fuel injection problem? Benzzy280 W123 E,CE,D,CD,TD,TE Class 0 02-12-2008 06:04 PM
    1984 SD 380 Fuel Injection Problem richard_john_81 General Mercedes-Benz 1 06-23-2006 10:36 AM
    1977 300D Fuel Injection Problem trickdog W123 E,CE,D,CD,TD,TE Class 3 03-23-2006 10:18 AM
