Mercedes ReCall (In Germany) - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 01-06-2010, 07:11 PM Thread Starter
Date registered: May 2004
Vehicle: '90 124.128
Quoted: 2 Post(s)
Daimler Replacing Fuel Nozzle on 4,500 Mercedes Cars (Update2) - Bloomberg.com
'You'll note all this information is weeks old...
The Bad News continues to Plague owners in the U.K. ,with no letup/final solution in sight!
You can follow the Continuing Horror Story @ the MB Club Forum UK post below.
Twenty five pages of posts as of last night.
The whole Delphi (5th generation of same faulty Injectors since last March) is supposed to
only be a "StopGap" until Bosch can solve the problem [We Can only Hope and Pray] and
"Tool Up" the proper Injectors(AND controller system).
Blue Efficiency injector recall? - MBClub UK Forums
These drivelines were the candidate for Diesel and Diesel/Electric Hybrid for the GLK
and "New" C class (to be assembled @ Vance [Tuscaloosa] )
Name:	ScreenHunter_01 Jan. 06 20.58.jpg
compress ignite is offline
post #2 of 3 (permalink) Old 01-06-2010, 11:03 PM
Diesel Benz's Avatar
Quoted: 35 Post(s)
Looks like it is too old news for anyone else seeking for a bump. What do you mean by Bosch solving the problem? Are they planning to start supplying an alternate part? So far it is simply an issue with Delphi injectors and their capability to supply new parts. Quite a big issue but both sides have done everything to solve the issue, except that MB could have initially selected another injector supplier.
Diesel Benz is offline
post #3 of 3 (permalink) Old 01-07-2010, 12:50 AM Thread Starter
Quoted: 2 Post(s)
Huh ?
Bosch was supposed to be the OE supplier...Until "Bean Counters" @ Deutsch Bank + Mercedes Sub'ed out the manufacture to Delphi for COST reasons...
Delphi is Incapable of producing Injectors THAT WILL "FIX" THE PROBLEM.
('Much less the necessary software and cpu to run the Injection system.)
All of the "Folderol" (Versions 1 through 6 of the Delphi Injectors) is simply a "StopGap" UNTIL BOSCH can Engineer and Produce a replacement Injection system.
[ALL of the affected (Effected?) vehicles WILL HAVE to be eventually
retrofitted with the BOSCH Injection System.](Whenever that becomes available)
    Mercedes Recall scottcardwell R230 SL-Class 2 06-25-2005 08:13 PM
    Mercedes Recall ByByeAmericanPie R170 SLK-Class 8 04-02-2005 12:09 PM
    Randy is there a general recall / fix going on in Germany that relates to the Vario roof? ianx, manchester R171 SLK-Class 8 11-11-2004 03:56 PM
    Mercedes USA/Germany Ivin W163 M-Class 16 05-15-2002 09:39 PM
    is all mercedes built in Germany???? Guest (MBNZ) General Mercedes-Benz 8 02-20-2002 03:51 AM
