Engine cuts out - Mercedes-Benz Forum
post #1 of 6 (permalink) Old 01-06-2010, 01:34 PM Thread Starter
Date registered: Jan 2010
Engine cuts out
I have a 1990 560 SEL with a V8. I starts a little rough in the AM and cuts out a ton gong up hills and when its cold. After drive for about an hour and I either slow way down or come to a stop. The car will sometimes die. Their is really no set time when it will act this way but I have narrowed it down to the above times. Any help is appreciated.
corptkm is offline
post #2 of 6 (permalink) Old 01-11-2010, 11:50 PM
Date registered: Apr 2009
Vehicle: Current: 1987 560 SEC US, former factory trained MB tech 10 years, owner of 14 others.
renaissance_warrior is offline
post #3 of 6 (permalink) Old 01-12-2010, 08:29 AM Thread Starter
Already had one a month a go
corptkm is offline
post #4 of 6 (permalink) Old 01-12-2010, 08:34 AM
Musikmann's Avatar
Quoted: 5 Post(s)
Please tell us what you just had done and we might be able to help by process of elimination. Also this is a general forum and there is one devoted to the W126 which is what you have. You might try posting this there too. Look under the sedans section.
Musikmann is offline
post #5 of 6 (permalink) Old 01-12-2010, 10:26 AM
Kajtek1's Avatar
Quoted: 1064 Post(s)
Typical symptoms of clogged fuel filter.
Kajtek1 is online now
post #6 of 6 (permalink) Old 01-12-2010, 12:01 PM
Supporting Vendor
FCP Euro's Avatar
Date registered: Jul 2008
Quoted: 22 Post(s)
It sounds like a fuel related issue. Either the fuel filter is clogging or the fuel pump is on it's way out. Check and see what the fuel pressure is at idle.
Quality & Service, Guaranteed for Life
FCP Euro - OEM & Genuine European Auto Parts Online
FCP Euro is offline
    engine cuts out Alph0nse V-Class 8 09-04-2009 02:08 AM
    engine cuts off campos W124 E,CE,D,TD Class 3 06-29-2009 01:16 PM
    Engine Cuts out Jippi W124 E,CE,D,TD Class 1 01-17-2007 12:55 PM
    Engine Cuts Out Kain W201 190-Class 3 04-06-2006 12:44 AM
    engine cuts out? gravel C208/A208 CLK-Class 1 12-03-2005 01:48 PM
