P0025 - "B" Camshaft Position - Timing Over - Retarded Bank 2 - Mercedes-Benz Forum
post #1 of 8 (permalink) Old 01-05-2010, 08:14 PM Thread Starter
Date registered: Jan 2008
i have a 2007 c230 yesterday i did an oil change and today the check engine light lid up with P0025
any one have any idea why this came out and how to fix it
jprosas is offline
post #2 of 8 (permalink) Old 02-17-2013, 01:45 PM
Date registered: Jan 2013
Vehicle: 2007 c230 Sport V6
Post
I have the same problem and I have p0015 code also
How did you solve it?
omarmaaroof is offline
post #3 of 8 (permalink) Old 02-20-2013, 08:17 PM
Date registered: Dec 2012
Vehicle: 87 560SL, 71 280SL euro, 74 VW Ghia, 78 280Z Black Pearl, 78 280Z, 04 Corolla, 07 Odyssey, 94 Prizm
what kind of C class do you have?? Is it a C230 or a C230 Kompressor?? The reason is that they are two totally different engines. One is a V6 and the other one is a 4 cylinder supergared inline 4.
OzzyQ80 is offline
post #4 of 8 (permalink) Old 02-20-2013, 11:16 PM
It is a V6 engine. can you show me on picture wich is bank 2 or B side of the engine? am totally confused on this. I also don't know the location of exhaust cam (magnet)
post #5 of 8 (permalink) Old 02-21-2013, 07:18 PM
cam arrangement on the M272 V6 engine goes like:
l ( ) ( ) l l ( ) ( ) l
\ A B \ / C D /
As viewed from the front of the engine to identify cam arrangement
Camshaft A is Right Exhaust
Camshaft B is Right Intake
Camshaft C is Left Intake
Camshaft D is Left Exhaust
You need to check the part number on the cam magnet. It should be A272 050 00 77. If it is, replace with updated part number A272 050 01 77. There is a recall on the harnesses since these cam magnets at times have been leaking oil thru the connector and possible contamination of the harness is possible, so there is a harness that is installed to protect the main harness from oil contamination.
Cheers!
OzzyQ80 is offline
post #6 of 8 (permalink) Old 02-21-2013, 07:21 PM
Are you using a generic code reader?? If I recall, the fault code should say something like "Continuous cam adjustment left bank (intake) Bla bla bla bla bla" (i don't quite remember it. If a generic code reader does not put it like that, it would be hard to know which bank it is since the code is usually very specific on which cam (intake or exhaust) and on left or right bank.
OzzyQ80 is offline
post #7 of 8 (permalink) Old 02-22-2013, 08:04 AM
Thank you man you are my hero....
I am using this'' 2012 new arrive ELM327 Interface Bluetooth OBD2 Auto Scanner V1.5 OBDII OBD 2 II car diagnostic from Jolin-in Car Diagnostic Cables & Connectors from Automobiles & Motorcycles on Aliexpress.com''
Actually I got the details as:
p0025 ''B'' Camshaft Position -Timing Over-Retarded
P0015 ''B'' Camshaft Position -Timing Over-Retarded
also
p0300, p0302, p0303 and p0306
by the way do you know the arrangment of the cylinders??
I have also
p2271 - O2 sensor Signal Biased/ Stuck Rich
p0136 - O2 Sensor Circuit
which belong to O2 sensor in bank1 sensor 2 that is in driver side(the lift side as veiwed from behind of the car) post-Cat.
post #8 of 8 (permalink) Old 02-14-2017, 02:52 PM
Date registered: Feb 2017
Vehicle: 2007 C280
P0025
Hello;
I have a 2007, C280. I keep getting the MIL light on with a fault code of POO25. I have replaced both hall sensors and the magnet sensor, Bank-1 (passenger side). The light continues to come back on after about 2/3 days. I read something about this being the left bank, magnet sensor and I would like to confirm either way. The car runs fine, no engine miss, starts well and drivability is good.
Any help is appreciated.
Thanks
lawfive1 is offline
Check Engine Light is ON, Read code P0025 (Camshaft/Timing), Please HELP!! bs79 W211 E-Class 4 12-09-2010 07:20 AM
Buffett: Bank woes are "poetic justice" Jakarta Expat Off-Topic 0 02-07-2008 01:46 PM
ordered "sport" 8 valve camshaft ! e34m20 W201 190-Class 4 11-21-2006 06:11 PM
Check Engine light ON- "Fuel Trim, Bank 1 & Bank 2" 99 C280 Sport timecop369 W202 C-Class 3 12-17-2002 05:00 PM
