Codes PO173, 170 - Mercedes-Benz Forum
post #1 of 8 (permalink) Old 01-05-2010, 10:08 AM Thread Starter
T4B
Date registered: Jan 2010
Vehicle: 2001 E320 All Black
Post Codes PO173, 170
My 2001 E320 was posting codes PO 170, 171, 173.
I cleaned my original MAF, with CRC cleaner, to no avail. I replaced the MAF with an autozone purchased MAF for $200. I now am getting codes of just PO 170, 173. Did I make a mistake of getting an autozone MAF, do I need to spend $529 at the dealership to get a mercedes MAF with a new time release virus?
I'd hate to start throwin 300+ at each O2 sensor.
Anyone who can help please do!!
Thanks,
Steve
T4B is offline
post #2 of 8 (permalink) Old 01-05-2010, 11:04 AM
Musikmann's Avatar
Quoted: 6 Post(s)
I don't know what your problem might be but you can buy a genuine Bosch MAF from online retailers for less than $529 (avoid eBay). Bosch says O2 sensors have a lifetime of 100,000 miles. Are yours anywhere near that old?
Come join us on the W210 forum, there are quite a few experts willing to lend a hand. Welcome to the forum.
Musikmann is offline
post #3 of 8 (permalink) Old 01-05-2010, 11:24 AM
Check Codes's Avatar
Vehicle: '01-E320 & 02-ST2
Quoted: 35 Post(s)
Steve, I can't add more to what MM said, except to tell you that the general forum can be kind of a wasteland at least as to specific things about specific models. The W210 forum is chock full of information about your car, so that's the place to head.
And BTW, the only thing I buy at Autozone for my 2001 E320 is oil, windshield washing fluid and car wash products. Genuine Bosch MAF at autohausaz.com is the way to go, about $175 with free shipping last time I checked.
Last, please click user cp and add your vehicle and location information to your profile as that is often useful.
See you in the 210 section.
Check Codes is offline
post #4 of 8 (permalink) Old 01-05-2010, 11:24 AM Thread Starter
T4B
Thanks,
Steve
The car currently has 79,000 on it, but this problem prolly started back about around 60k.
I keep clearing the CEL, but it always comes back on within 20 miles,
and I can't stand seeing it anymore.
I've already replaced the whole exhaust system once, and Im afraid if I keep
driving with this problem, I'll have to do it again.
The MAF I bought at autozone came in a Bosch Box, So I assume it is a genuine
Bosch Product.
Steve
T4B is offline
post #5 of 8 (permalink) Old 01-05-2010, 11:26 AM
Quoted: 35 Post(s)
Steve
That pretty much confirms it's the MAF, since when it fails it cooks the cats if it's ignored long enough. Get that Cardone unit out of there and replace with bosch, check the intake tube to make sure it's all connected properly as well when you change it.
Fix the problem, don't just clear the codes. If you're going to DIY, spend time in the 210 forum so you do it right, otherwise drop off the car and your bank account at the dealer.
post #6 of 8 (permalink) Old 02-16-2010, 05:12 AM
Date registered: Feb 2010
Vehicle: Snow White 2001 E320
Codes PO170 & 173
Hi Steve,
I'm new to this forum and just bought my wife an '01 E320 6 days ago. The CEL was on and I had the same codes. After joining this forum and searching I also found the threads on cleaning the MAF sensor. So far so good after a good clean. I also cleaned the OEM air filter as well. I want to change out the OEM air filter to a K&N just to get better air flow.
I guess I got lucky on just cleaning it. Maybe you have a bigger issue but I'll stay tuned to follow this thread in case my CEL comes back on. Sorry I couldn't be of more help but the simple clean has solved my problem so far.
The car we bought has only 55K miles and is in MINT condition. It has only been driven 4000 miles in the last 2 years.
Thanks to everyone for the info,
Shawn
srmack is offline
post #7 of 8 (permalink) Old 02-16-2010, 08:38 AM
Date registered: May 2005
Vehicle: '07 GL320CDI
Quoted: 2 Post(s)
You won't.
But the oil mist will ruin your MAF.
It's a Mercedes--there's nothing wrong with the OE intake system.
Kent Christensen
Albuquerque
'07 GL320CDI
lkchris is offline
post #8 of 8 (permalink) Old 02-16-2010, 02:42 PM
Todd157k's Avatar
Vehicle: 1999 SLK230 M5
There are several things to cause a lean code. Start with the simple ones which is the intake AFTER the maf. Make sure the system is secure and no cuts/splits in the intake ducting. Secondly, you said you replaced the exhaust system.. are you sure the O2 sensor wires are clear of the exhaust piping/manifolds?
Usually problems like this are nothing more than a torn/split intake tube.
2006 SLK55
2006 CLS500
1999 Mercedes SLK230 Manual
2004 Z06 525rwhp/460rwtq
2005 Dodge Ram Daytona 4x4
Todd157k is offline
    Error codes PO170 & PO173 - ? Dadaman General Mercedes-Benz 8 04-22-2011 01:27 PM
    codes PO173, PO170 & PO446 kwiklee W163 M-Class 2 08-13-2007 07:08 PM
    '99 C280 with Check Engine Light - Codes PO170 & PO173 1957Birdman W202 C-Class 8 04-20-2007 09:25 AM
    Pollen Season = CEL = PO170 & PO173 Codes CCORLEY W163 M-Class 1 05-16-2005 09:59 AM
    Pollen Season = CEL = PO170 & PO173 Codes CCORLEY W163 M-Class 1 05-15-2005 06:46 AM
