Engine dies while driving. Help! - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 01-04-2010, 11:48 PM Thread Starter
Date registered: Jan 2010
I have a problem which i hope you won't mind reading. I drive an MB 230E 124-body 1989 model manual transmission sedan. The problem is that it dies while i'm driving and i noticed the ABS dashboard lamp turns on. At first i thought it had to do with the ignition coil (w/c i replaced) but no. Now it dies only after 4-5 minutes of idling and the ABS lamp comes on. I can't drive it anymore bec. it'll die on the road for sure. Some say it's the fuel filter or the fuel pump relay, or the fuel pump itself, or the over voltage protection relay, or perhaps the distributor cap, or the battery itself. i'm confused now. Any assistance is appreciated. Thank you.
RGN07 is offline
post #2 of 3 (permalink) Old 01-05-2010, 09:34 AM
Date registered: Dec 2008
Vehicle: w204 (C350ELE)
You are facing a situation that requires patience to follow the electrical crumbs so a correct diagnosis can be made. Take it to a good MB indie, you'll save money in the long run.
A car would show appreciation for preventive maintenance by never leaving his owner stranded.
Defensive Driving is never having to say you're sorry: a true love story between man and machine.
JoeVal is offline
post #3 of 3 (permalink) Old 01-05-2010, 10:13 AM
Kajtek1's Avatar
Quoted: 1070 Post(s)
Common issue is that ABS light come on at low voltage, so my first guess would be that you have a problem with charging system where low voltage is killing ignition or fuel pump.
Shouldn't be too hard to hook up voltmeter? Even the plug-in one with LED lights on it.
Kajtek1 is online now
    190E 2.6: While running/driving, engine "stalls", tach dies, BUT..... lars-tetens W201 190-Class 18 07-30-2009 07:19 PM
    Engine trembles and dies while driving. FUEL PUMP?? BenzWithers W124 E,CE,D,TD Class 7 03-31-2009 11:12 PM
    HELP!! 91 260E engine dies after driving just a few miles. Cold start OK. danieldjx W124 E,CE,D,TD Class 0 02-27-2008 05:15 AM
    HELP!! 91 260E engine dies after driving just a few miles. Cold start OK. danieldjx W124 E,CE,D,TD Class 0 02-27-2008 04:59 AM
    Engine dies when driving fast or up-hill privremena_adresa General Mercedes-Benz 20 11-01-2006 07:01 AM
