2007 E Class uk model 220 cdi W211 - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 01-03-2010, 11:31 AM Thread Starter
Date registered: Aug 2009
Am I right in thinking that this model does not have an Aux battery as there is no sensotronic brake system.
I have looked under the bonnet but how do you remove the plastic engine cover over the main engine block.
Regards,
Malcolm
dibdabsara is offline
post #2 of 3 (permalink) Old 01-03-2010, 12:15 PM
Kajtek1's Avatar
Quoted: 1248 Post(s)
W211 section would be more appropriate for the question.
No 220cdi was ever sold in USA, but in 320cdi the aux battery is under cabin filter right under the windshield on passenger side.
Obviously since you likely have the steering wheel on passenger side it might be reversed in your car.
Do you have manual? I posted link to E320cdi manual in W211 section.
Welcome to the forum.
Kajtek1 is offline
post #3 of 3 (permalink) Old 01-03-2010, 12:21 PM
Diesel Benz's Avatar
Quoted: 39 Post(s)
Regards,
Malcolm
Yes, the answer should be available from the W211 forum but you are right, a facelift W211 does not have any AUX battery any more. The battery was not located under the engine cover but under the dust filter.
I did not check if it is the same with the 220CDI but I assume you just pull it up like on a V6 engine. On older engines the cover was fixed with bolts that were easily visible from the top.
Diesel Benz is offline
    Battery Alternator visit work shop (Mercedes C class CDI 220 (2001/2002 model)) Jordon W202 C-Class 7 08-06-2011 05:21 PM
    mercedes 2007 220 cdi E class dibdabsara General Mercedes-Benz 0 11-23-2009 05:31 AM
    Battery Alternator visit work shop (Mercedes C class CDI 220 (2001/2002 model)) Jordon W203 C-Class 1 08-05-2009 12:50 PM
    2004 220 CDI (W211) , power down limp mode on, any help? redwings91 General Mercedes-Benz 2 01-13-2009 10:33 AM
    v 220 cdi v class mpv shaney Test 1 11-16-2006 01:29 PM
