Auto Gearbox problem, Not shifting out of 1st gear. - Page 2 - Mercedes-Benz Forum
post #11 of 12 (permalink) Old 01-21-2010, 12:22 PM
keyhole's Avatar
Date registered: Sep 2006
Vehicle: 2004 CLK 240 Coupe
Quoted: 404 Post(s)
This is all I can find in the WIS about Limp- home mode.
keyhole is offline
post #12 of 12 (permalink) Old 01-21-2010, 02:31 PM Thread Starter
Date registered: Jan 2010
Vehicle: Mercedes CLK 230 K
My plot thickens more than ever.
car was in limp mode, i drove it to work (in 2nd gear) so i could get the codes cleared, while it was there, before the codes were read/erased, it decided it wasn't going to start, all ignition lights on, but didnt want to crank. i elliminated the immobiliser by bridging the starter solenoid and it started, but just wouldn't start on the key.
hooked up the diagnostics and no faults in the engine ecu, 5 random faults in the gearbox (havent got them to hand)
cleared them and fixed the problem, now starting on the key, and not in limp mode (although it was still initially in limp mode for half a mile and switching engine off and restarting, i assume its a learning excercise?)
anyway, touch wood it will still be ok tomorrow, and so on...
strange though how a gearbox fault code will prevent the engine from cranking, any ideas why? (1 of the codes was to do with the gear selector, i assume a fault where it thinks its in a drive gear rather than park/neutral which of course will prevent the starter operating, but how could that fault appear when the inhibitor switch is clearly ok. i'm baffled.
awiserbud is offline
400E Transmission Shifting from 1st to 3rd gear luis77 W124 E,CE,D,TD Class 9 03-03-2013 09:28 PM
auto gearbox does change gear carlwil V-Class 2 03-09-2009 12:39 AM
Gearbox sticks in 1st gear - ML 270 shatav W163 M-Class 3 12-28-2006 12:10 PM
Gearbox problems - Only 1st Gear Available baugh W140 S-Class 14 09-02-2006 07:05 PM
Q: Auto Tranny shifting from 2nd to 1st becoming harsh... benkokes R170 SLK-Class 1 01-29-2003 04:30 PM
