my car shakes when i start it up - Mercedes-Benz Forum
post #1 of 9 (permalink) Old 01-02-2010, 04:49 AM Thread Starter
CLK KID's Avatar
Date registered: Dec 2009
Vehicle: 1999 clk320
Send a message via AIM to CLK KID
Angry my car shakes when i start it up
on rare occasion my 1999 clk 320 will shake upon start and i see the rpm shaking also, and sometimes when im driving it will do it and when i give it gas the car wants to move but stutters like its going to stall, ill have it floored then it will just be doing 5 mph then i will have to ease off the gas and wait for it to stop, its very rare when it does this and happens only for a few seconds, some one said it could be the spark plugs im going to look into that, i hope its nothing serious.
1999 Mercedes Benz clk 320- with 19's
2005 Polaris predator 500 (troy lee edition)-full white brothers exhaust
Ruff Ryders!
CLK KID is offline
post #2 of 9 (permalink) Old 01-02-2010, 11:44 AM
Date registered: Apr 2009
Vehicle: Current: 1987 560 SEC US, former factory trained MB tech 10 years, owner of 14 others.
I would run a can of 44k in the fuel. It sounds like somethin is stickin in the air delivery system in the cold-start circuit. Probably just fuel varnish.
renaissance_warrior is offline
post #3 of 9 (permalink) Old 01-03-2010, 04:40 AM Thread Starter
CLK KID's Avatar
Lightbulb
my check engine light came on and it said i need an oxygen sensor could that be the problem?? it happens wen i start it if its really cold out and randomly when im driving
Ruff Ryders!
CLK KID is offline
post #4 of 9 (permalink) Old 01-04-2010, 12:19 PM
Date registered: May 2005
Vehicle: '07 GL320CDI
Quoted: 2 Post(s)
If it shakes it means it isn't running on all six cylinders.
Kent Christensen
Albuquerque
'07 GL320CDI
lkchris is offline
post #5 of 9 (permalink) Old 01-04-2010, 12:25 PM
Musikmann's Avatar
Quoted: 6 Post(s)
An out of range O2 sensor will cause a CEL. Average lifetime on those is 100,000 miles. Did your car tell you that or did you have it scanned for error codes?
Musikmann is offline
post #6 of 9 (permalink) Old 01-04-2010, 01:53 PM
Date registered: Nov 2009
Vehicle: 2001 S55 AMG
Could be bad spark plugs, also motor mounts can make the car shake if they are weak.
But if you codes tell you O2 sensors, take a look at that first and narrow it down from there.
crashtest is offline
post #7 of 9 (permalink) Old 01-04-2010, 03:44 PM
Date registered: Dec 2008
Vehicle: w204 (C350ELE)
Post
Is your catalytic converter in your exhaust? Otherwise, it got finally clogged.
Also, clean your fuel intake. It must have obstructions to a free fuel mix flow.
Cheers,
A car would show appreciation for preventive maintenance by never leaving his owner stranded.
Defensive Driving is never having to say you're sorry: a true love story between man and machine.
JoeVal is offline
post #8 of 9 (permalink) Old 01-05-2010, 07:03 PM Thread Starter
CLK KID's Avatar
yea my check engine light came on and said an o2 sensor needed to be replaced and whats a CEL?
p.s. my car has 172,000 miles on it!
and thank you all for the help its helped me alot thanks to all
Ruff Ryders!
CLK KID is offline
post #9 of 9 (permalink) Old 01-05-2010, 08:22 PM
Musikmann's Avatar
Quoted: 6 Post(s)
Originally Posted by CLK KID View Post
yea my check engine light came on and said an o2 sensor needed to be replaced and whats a CEL? p.s. my car has 172,000 miles on it! and thank you all for the help its helped me alot thanks to all
Sorry CEL means check engine light. Your O2 sensors are way past due if not replaced before now.
Car shakes bloodpirate W124 E,CE,D,TD Class 5 01-20-2010 05:31 AM
car shakes at idle psharpster W203 C-Class 21 04-06-2008 03:45 PM
Another problem, My car shakes... richt420 W220 S-Class 3 01-14-2008 08:35 PM
car shakes while stopping in D bulahee W201 190-Class 7 12-22-2005 11:20 AM
my car shakes when i turn it off... krk230 R170 SLK-Class 9 08-18-2004 08:15 PM
