vibrations - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 01-01-2010, 08:49 AM Thread Starter
Date registered: Dec 2009
Vehicle: 1991 sel560
vibrations
hi all , im the proud owner of a 91 560 sel had some vibration issues for monthes now, mostly at speeds starting at 60mph and gets worse the faster ya drive, replaced wheels had them load balanced,several times, then finally took it to another alignment shop the mech couldnt find anything wrong with the front end he did mention that the center carrier had a slight bit of play and that the rear suspenion was too bouncy, he thought maybe the accumulators being shot caused the angle of the driveline to be off causing the vibration but wasnt sure because he hadnt worked on them much, think ill replace the accumulators center carrie flex disks and perhaps the transmission mounts as long as im gonna be under there, any thoughts or tricks i should no before tackling the job thanks in advance
craigboesenberg is offline
post #2 of 2 (permalink) Old 01-01-2010, 08:31 PM
leapyfish's Avatar
Date registered: Apr 2008
Vehicle: 1998 SLK230 210,xxx Miles
Quoted: 6 Post(s)
leapyfish is offline
More vibrations bullockandrew R129 SL-Class 3 12-01-2007 10:36 PM
Vibrations Judas W140 S-Class 6 11-30-2005 05:05 AM
Vibrations ack W163 M-Class 29 10-14-2005 08:17 AM
Vibrations... Braingears G-Class 9 08-10-2004 07:28 PM
Vibrations..... CustomSLKIOM R170 SLK-Class 0 02-27-2003 05:54 AM
