C180 1999 Central Locking Problem - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 12-30-2009, 04:04 AM Thread Starter
Date registered: Sep 2008
Gave a jumpstart to a friend with flat battery - and now my central locking does not work - cannot open boot, either with electronic key or from button inside car.
Did not get key to 'manually' open car when I bought it.
Could the jumpstart have caused something to blow? A fuse? ... where is the fuse?
The indicators flash as normal when I click the electronic key - but nothing happens, so I cannot lock car from outside, or open boot.
Any info much appreciated. Thanks.
Tom Kelly is offline
post #2 of 3 (permalink) Old 12-30-2009, 05:47 AM
Date registered: Dec 2002
Vehicle: 92 500SEL to 01 E320T current 2014 lexus LS460
Your dealer can order a manual key usually overnight!
Peter Guenther is offline
post #3 of 3 (permalink) Old 12-30-2009, 06:19 AM
Musikmann's Avatar
Quoted: 5 Post(s)
The manual key should be tucked into the smart key. Look for a switch lock on the back side, push it to the side and if you have one, the key should slip out. My car has 3 fuse/relay boxes but I don't know about yours. Check your owner's manual for locations or ask on the W202 forum (sedans section). Hopefully it is only a blown fuse or relay. Good luck and welcome to the forum.
Musikmann is offline
    S320 W220 1999 central locking fault nitegrooves W220 S-Class 12 06-09-2012 12:56 PM
    C180 1994 - Central Locking, grizzly_b W202 C-Class 2 07-14-2009 01:42 AM
    C180 central locking system t512419 W202 C-Class 3 04-14-2009 09:21 AM
    central locking problem.. myim74 R170 SLK-Class 11 02-07-2009 02:56 AM
    Where is Central Locking Pump on 1999 C230? Guest General Mercedes-Benz 0 08-31-2005 09:35 PM
