CDI hard start - Mercedes-Benz Forum
post #1 of 8 (permalink) Old 12-29-2009, 07:30 AM Thread Starter
Date registered: Feb 2006
CDI hard start
MY 99 220cdi have trouble starting after about 8 hours not driving, i have change all the o-rings in the fuel line, when i stop the engine i can see the diesel running back in the tank, i can see air coming in the fuel line after the shot off valve (a6110780049) can it be fault ? ore what can i try ?
ospdk is offline
post #2 of 8 (permalink) Old 12-29-2009, 10:56 AM
Diesel Benz's Avatar
Quoted: 39 Post(s)
This does sound like a leak at the fuel lines. Can be difficult to find, I wish you luck. Perhaps the W210 section could help with their experience.
Diesel Benz is offline
post #3 of 8 (permalink) Old 12-29-2009, 12:20 PM
Kajtek1's Avatar
Quoted: 1289 Post(s)
Not too many cdi in W210, but leaky fuel lines on older diesel have whole book of topics.
The constant advice I am giving to fellow owners of aging diesel engines is to get whole set of plastic tubings with oring on them and replace them all at one time including oring on SOV.
On older diesels (not cdi) parts cost around $80 from Internet dealer.
Kajtek1 is offline
post #4 of 8 (permalink) Old 12-30-2009, 10:52 AM Thread Starter
One way valve
Changed all the fuel lines and o-rings without any luck, mounted a one way valve just before the fuel filter and that solved the issue.
ospdk is offline
post #5 of 8 (permalink) Old 12-30-2009, 10:59 AM
Quoted: 39 Post(s)
Sounds odd, unless there was a leak exactly at those hoses. Do you mean the fuel line from the tank to the fuel filter or the fuel line from the fuel filter to the tank? Or perhaps at the other side of the fuel filter? I'd like to understand why the valve made this difference.
post #6 of 8 (permalink) Old 12-30-2009, 11:20 AM
Kajtek1's Avatar
The valve might be a patch downstream from the leak.
The leaks on fuel lines operating at vacuum is hard to detect even with clear lines that are there just for that.
IMHO the main problem still exist and at one point it might become big enough to trigger a problem where check valve will not help.
I am not familiar with fuel lines on the cdi engine, but on older diesel common problem is that owners replace all the fuel lines with orings on them and have no idea there is 1 more oring hidden on other side of SOV.
Kajtek1 is offline
post #7 of 8 (permalink) Old 12-30-2009, 12:26 PM Thread Starter
Valve
I placed the valve just before the fuel filter from the tank (between fuel cooler and filter) in old models there was a one way valve inside the pump don't know if it is the same with this one, and that is causing the problems.
When i turn of the engine i can see the fuel running back about 10cm from filter to tank, and over night that become more and causes the problem starting.
ospdk is offline
post #8 of 8 (permalink) Old 12-30-2009, 01:22 PM
Quoted: 39 Post(s)
Doesn't that mean a leak at the other side of the one way valve, the valve prevents the small vacuum at the tank draining the fuel from the line? If there was no leak, the vacuum would be equal at the return line and it would prevent the fuel movement you observed?
No start/Hard Start condition.... forcefed44 W126 S,SE,SEC,SEL,SD,SDL Class 1 10-01-2009 08:34 PM
No start-Hard start, multiple cranks, Help??? gquarrick W210 E-Class 13 11-24-2008 03:16 PM
sl500 cold start fine-short trip park restart rough idle hard start?? dpol1835 R129 SL-Class 7 01-02-2006 06:33 AM
Cold Start? hard to start after temp drops Prissy6990 W126 S,SE,SEC,SEL,SD,SDL Class 4 02-15-2005 06:51 PM
Hard start or second start when warm high hc level-- beware major expense Peter Seow W126 S,SE,SEC,SEL,SD,SDL Class 1 07-03-2004 06:23 PM
