320CE grating sound when cornering - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 12-27-2009, 08:34 PM Thread Starter
Mr T 320CE's Avatar
Date registered: Aug 2009
I have a 1995 320CE bought recently, drove very well on purchase and still continues to fell strudy and precise. However, the last couple of weeks a grating sound has developed when cornering. This was more pronounced when I had a passenger in the rear. The car has a skirt, although not particularly low, and the car didn't make this noise when I first got (and I drove it harder when I first got it to try out the 3.2 litres!). The shocks were replaced by the previous owner only 7000 kms ago and the noise comes from both sides, so I assume this is not the problem. A friend suggested it could be the bushes, is this a common problem with this model? I'm not mechanically minded and don't really know how the bushes work, appreciate some advice.
Mr T 320CE is offline
post #2 of 4 (permalink) Old 12-29-2009, 04:53 AM
CLK KID's Avatar
Date registered: Dec 2009
Vehicle: 1999 clk320
Send a message via AIM to CLK KID
Lightbulb hmm
i have a clk 320 and when i first got the car the owner had like 5 pounds of air in all the tires and the was a small dent on the inside of of the tire which meant the metal inside the tire was bent so when ever i turned right it would make a loud thumping noise, i don't know what kind of noise u are hearing but it starts off very small and now it got so bad that the steering wheel shakes so i had to replace the two front tires and since i have 19 inch rims it cost me 300 bucks :/
just somthin to look out for if its a thumping noise
1999 Mercedes Benz clk 320- with 19's
2005 Polaris predator 500 (troy lee edition)-full white brothers exhaust
Ruff Ryders!
CLK KID is offline
post #3 of 4 (permalink) Old 12-29-2009, 09:48 AM
Musikmann's Avatar
Quoted: 6 Post(s)
Sounds like the suspension. I think you have lower control arm bushings and sway bar bushings. Take it to a suspension shop and have them check those out. It might be something else but bushings do wear out and you have a 15 year old car so those are probably due to be replaced.
Musikmann is offline
post #4 of 4 (permalink) Old 12-29-2009, 09:58 AM
Date registered: May 2005
Vehicle: '07 GL320CDI
Quoted: 2 Post(s)
Could be motor mounts.
Could be heater box contacted by blower squirrel cage.
Kent Christensen
Albuquerque
'07 GL320CDI
lkchris is offline
    Grating Sound - Seized A/C Compressor? Clutch? Jase W202 C-Class 16 06-23-2009 01:50 PM
    Roaring Sound Like Driving On A Metal Grating? Moe W126 S,SE,SEC,SEL,SD,SDL Class 1 11-27-2008 07:56 AM
    My car MB 320CE Bullet W124 E,CE,D,TD Class 1 12-03-2003 01:45 PM
    Anyone experiencing grating sound from engine when hot? Robbie R170 SLK-Class 0 04-27-2003 06:29 PM
    1995 320ce ibrahim83 W124 E,CE,D,TD Class 2 12-08-2002 03:42 PM
