Sagging Headliner - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 12-27-2009, 05:19 AM Thread Starter
Date registered: Dec 2009
Sagging Headliner
Hi Guys,
I'm new to this forum. I decided to join because I love all things Merc.
My car is a W123 originally with the OM616 which I upgraded to the OM617 (non-turbo) and it now runs beautifully with just a couple of glitches.
The headliner is sagging at the rear because it seems the thin support wire came out of position. I know there must be many threads on this and I don't mind searching previous threads before bothering members.
The second issue is a little more mysterious. Since changing the engine, it runs well 90% of the time with the temp between 80C and 100C. If I drive at over about 120kph sustained, the temp heads towards the red. The same thing happens with long hills. Also the temp gauge seems to flicker without any sort of pattern when hot.
The radiator is the original 616 unit as is the mechanical fan. Any ideas? The engine has no coolant leaks.
Joe
tumbili50 is offline
post #2 of 3 (permalink) Old 12-27-2009, 08:48 AM
leapyfish's Avatar
Date registered: Apr 2008
Vehicle: 1998 SLK230 199,xxx Miles
Quoted: 4 Post(s)
leapyfish is offline
post #3 of 3 (permalink) Old 12-29-2009, 01:34 AM Thread Starter
Thanks for the useful direction leapyfish. I am now going through the discussions and believe this is where I need to focus.
    Headliner sagging sbaert W124 E,CE,D,TD Class 42 05-26-2016 09:30 PM
    Hardtop Headliner Sagging jnf300sl R129 SL-Class 15 12-31-2010 04:53 PM
    SEC Headliner Sagging MBL87560SEC W126 S,SE,SEC,SEL,SD,SDL Class 5 06-26-2006 02:48 AM
    What is the best way to reattach my sagging headliner? SheepAlert W126 S,SE,SEC,SEL,SD,SDL Class 3 04-25-2003 04:14 PM
    Sagging headliner irish sean G-Class 2 02-04-2002 05:46 AM
