bridge out an ML270CDI fuel pre-heater? - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 12-27-2009, 04:19 AM Thread Starter
Date registered: Jun 2007
Vehicle: W123 300D 1981; W163 ML270CDI 2002; w463 G300D 1994
Hi there
Does anyone know if there will be any adverse effects if I bypass the diesel pre-heater? The elbow on my ML270CDI has cracked on the intake side. I have managed to perform a temporary fix by repairing it with pratleys quick steel. If it cracks off again can I bypass it and feed the "cold" fuel straight into the outlet pipe (pipe goes into the Bosch injection rail)? I am in the middle of nowhere and can't get a replacement part straight away. Anyone know if driving for prolonged periods can do any damage if I bridge it out?
Surely the diesel is cold on startup until the radiator is hot enough to heat the diesel anyhow? Bearing in mind I am in South Africa and current temperatures are about 35 degrees C and going to get hotter as I am on my way to Namibia.
Any help would be much appreciated.
Regards
Darcy
munga123 is offline
post #2 of 3 (permalink) Old 12-27-2009, 06:01 AM
Diesel Benz's Avatar
Quoted: 35 Post(s)
You must mean the fuel cooler? CDI engines need a fuel cooler at the return line to keep the fuel cool enough for the tank. At some testing a plastic fuel tank melted from the fuel heat. A CDI high pressure pump heats up the fuel a lot, could be specifically an issue at your place but also at cooler places.
Diesel Benz is offline
post #3 of 3 (permalink) Old 12-27-2009, 01:02 PM
Kajtek1's Avatar
Quoted: 1163 Post(s)
Rare engine, so hopefully you will find a member with direct experience, but to my knowledge any bypass will trigger an error. Even you can ignore the error it will become annoying over the time, so you will want to fix it right sooner or later.
Kajtek1 is offline
    bridge out an ML270CDI fuel pre-heater? munga123 W163 M-Class 0 12-27-2009 04:15 AM
    Did the 300SDL ever come with the Webasto pre-heater option...? MBinIL W126 S,SE,SEC,SEL,SD,SDL Class 6 12-15-2009 07:00 PM
    E220 CDi Cabin pre-heater tamrsoft W210 E50 AMG, E55 AMG 1 09-14-2005 06:45 AM
    Do I need to change the fuel pre-filter? MBeige W123 E,CE,D,CD,TD,TE Class 37 09-29-2004 01:35 PM
    Fuel Pre-Filter Fiddlefoot W123 E,CE,D,CD,TD,TE Class 2 05-12-2004 09:42 AM
