560SL M119 conversion - Mercedes-Benz Forum
post #1 of 1 (permalink) Old 12-20-2009, 06:19 PM Thread Starter
Date registered: Apr 2008
Vehicle: Mercedes 1980 6.9 Euro Mercedes 1984 190E Euro 3.2 24v M104 Project Mercedes 1985 500SEC Euro soon t
Does anyone know if anyone has ever put a m119 5.0 engine in a 560SL or similar car?
I'm working on building one and looking for some tips on motor mount ideas, and if the stock exhaust manifolds fit. I've found the oil pan is interchangeable with an sl so that wont be a problem and i am converting it to manual transmission witch has gone well. so now i need to figure out the motor mounts any ideas? SL 129 are too shots and s500 too low. 107 will bolt on one side but exhuast is in the way on the other side, do 400e or anything have different motor monunts or something that might work?
Actave is offline
    Do late M119 heads fit M117 or only early M119 StreekG W126 S,SE,SEC,SEL,SD,SDL Class 42 09-25-2013 03:18 AM
    560SL Manual transmission conversion, Crank position sensor Help? Actave R/C107 SL/SLC Class 15 08-12-2009 03:03 PM
    M119 Conversion jhodg5ck W126 S,SE,SEC,SEL,SD,SDL Class 11 02-18-2006 02:27 PM
    M117/M119 Conversion AxelWulff W126 S,SE,SEC,SEL,SD,SDL Class 5 08-11-2005 03:27 PM
    Pictures of my "widebody" conversion and 2002 front end conversion. Chris Krikorian W163 M-Class 6 09-05-2002 09:48 AM
