QUESTION: Will a 2500 watt power inverter damage my Benz? - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 12-20-2009, 05:25 PM Thread Starter
Date registered: Sep 2009
Vehicle: 2000 C230 Kompressor
Thinking of using a 2500 W/5000W DC to AC Power Cigarette Lighter Inverter to charge my iPhone and run external speakers.
I drive a 2000 C230.
Any chance this setup will create electrical issues?
Esquire69 is offline
post #2 of 4 (permalink) Old 12-20-2009, 05:53 PM
e-420's Avatar
Date registered: Sep 2008
Vehicle: 1997 E-420 (150K miles), 1997 SL500, (90K miles) 2015 GMC Sierra Denali 2500HD CC/SB/4x4 Duramax
Quoted: 400 Post(s)
probably not damage, but you likely won't be happy. good chance you'll blow the cig lighter fuse as the inverter starts up. you CAN NOT get more than about 150 watts from a cig lighter inverter w/o blowing a fuse. a 2500 watt inverter will draw over 200A at full power and way more than needed quesently. (and at full power destroy a normal car battery in short order car starting batteries aren't meant to deliver 100+ amp for moe than 30 seconds or so, that's what deep discharge batteries are for, but they aren't good starting batteries) and it is way overkill for what you want to do. You don't need more than about 25W to charger a phone. stick with a 100watt or less inverter if you want to use it off your cig lighter. any real 2500 watt inverter will NOT be sold with a cig lighter cable, it would take a 2/0 or so direct connection to the battery. And a real 2500 watt inverter is going to be larger, like close to the size of a shoe box. a 50 or 100 watt inverter can be pretty small, not much bigger than a cell phone.
--------His------------Hers-------
97 SL500 Imperial Red
/Parchment Leather/Black Top
Chromed OEM wheels, Akebono's, H1+90 fog, Burlwood/Leather shift knob, Rostra Lumbar support, Check seat heaters, Bilstein's, Parrot Bluetooth, GG Bailey Custom cargo mat, GG Bailey trunk mat, Real Burlwood Instrument Cluster w Chrome rings, Burlwood & Chrome shift surround, Euro headlights with Osram 70W/65W H-4's, clear corners, Silverstar corner lamps, Euro Trunk mount Warning triangle, SL600 Burlwood armrest trim & Burlwood cupholder sliding cover, Kahtec flashing third brake light (CHMSL)
97 E420 Royal Indigo/Grey Leather
Raintracker wiper, Rostra Lumbar support, Parrott Bluetooth, 17" chrome AMG replica wheels, Bilstein's, Akebono's, smoked marker lights, Osram 65W H7's, H1+90 fog, Rear Seat Child restraint Tether, Burlwood/Leather shift knob, OEM Mudflaps, DRL's, Becker Aux input
e-420 is offline
post #3 of 4 (permalink) Old 12-20-2009, 05:56 PM
Date registered: Jul 2004
Quoted: 338 Post(s)
That doesn't sound like a good idea off the cigarette lighter. I don't see why you couldn't hook directly to the battery, and get a good 3 to 5 minutes of loud music. I would think an external battery would be the way to go.
deanyel is online now
post #4 of 4 (permalink) Old 12-21-2009, 03:44 PM
Date registered: Feb 2008
Vehicle: 2004 W220 (S430) ; 2001 R129 (SL500) Sport
Location: Alabama Gulf Coast--formerly Charlottesville, VA
Did you type an extra zero in your question? I'm with e-420; I can't imagine that you have a real need for that much wattage unless you're driving speakers the size of your car. Less is more. Satisfy yourself with smaller everything in this case so you spare the battery, charging system, and wiring in your car.
Good luck.
"Don't pick a fight with an old man. If he is too old to fight, he'll just kill you."--John Steinbeck
DrJfrmLA is offline
Used a power inverter in the cig lighter plug, didn't work, now stereo isn't working! yeauxyo W126 S,SE,SEC,SEL,SD,SDL Class 10 04-02-2008 10:44 AM
power inverter for rear dvd system vinceching W164 M-Class 0 06-03-2007 11:23 AM
1998 Mercedes Benz SLK 230 - Parts Car - $2500 - Seattle koaea R170 SLK-Class 0 04-13-2007 12:27 PM
will a 250 watt amp melt a 225 watt wiring kit? iNeon Audio & Telematics Forum 9 11-09-2005 04:20 PM
Can anyone recommend a power inverter for the SLK? dbottoms R170 SLK-Class 3 01-15-2004 02:36 PM
