95 E320SE: Heater Blower Suddenly Quit? - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 12-19-2009, 01:05 PM Thread Starter
Date registered: Nov 2009
Unhappy 95 E320SE: Heater Blower Suddenly Quit?
I had a rebuilt Denzo A/C Compressor put in my 95 E320SE, back in May. My A/C and heat worked fine for the last six months until inexplicably nothing came out of my heater last week.
The system showed no signs of sputtering or lagging. One day the heater worked, the next day nothing. We checked the outside fuse box and the fuses looked fine. However, I did eventually hear some faint sounds emanating from the A/C a few days later--just with no air.
Would the heater/ blower motor do this or is this some other electrical glitch or switch? I would just expect some warning signs to surface with the fan/ blower.
ConfusedByMyBenz is offline
post #2 of 3 (permalink) Old 12-19-2009, 07:59 PM
Administratoris Emeritus
GeeS's Avatar
Vehicle: 2021 SL770
Quoted: 544 Post(s)
Your motor is probably fine, most likely culprit is the blower regulator, depending on what kind of car you drive*. And I agree, a failing motor can usually be expected to exhibit symptoms before quitting completely.
* No such thing as a "E320SE" (???)
GeeS is offline
post #3 of 3 (permalink) Old 02-13-2010, 11:38 AM
Date registered: Jan 2010
I have a similar story: my 1998 C Class heaters suddenly stopped working properly: it would work at (say) blower speed 3 and above but 3 would work at expected level of speed blower speed 1 setting. Then it stops working altogether for bit, then works as normal and so on. I had a second hand regulator fitted and blowers worked 100% for about three days now the exact same problem is occurring. I can't help feeling it's not the reg. Been told it may be gunked up brushes on the motor but cannot get motor off: removed four screws and the entire unit was really loose but would not detach. What have I missed? I can't work on it in situ without becoming a contortionist!
mucky neighbour is offline
    Blower just quit! Jayare W124 E,CE,D,TD Class 35 02-07-2011 05:52 AM
    Blower motor quit yesterday hheynow W123 E,CE,D,CD,TD,TE Class 16 02-01-2010 04:48 PM
    380 SEC Heater and A/C dead - blower stopped suddenly SECBenz W126 S,SE,SEC,SEL,SD,SDL Class 0 10-02-2009 05:55 AM
    It can't be!!!!! - Blower quit and smack W126 S,SE,SEC,SEL,SD,SDL Class 20 08-27-2009 03:19 PM
    s500 heater suddenly stopped working mendahl W140 S-Class 4 01-09-2007 12:04 PM
