BATTERY LIGHT CAME ON THIS MORNING - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 12-18-2009, 09:21 AM Thread Starter
Date registered: Dec 2009
Vehicle: 06 E55 AMG
Send a message via AIM to armanix713
STARTED MY CAR UP THIS MORNING IN NY.. MMMM 18 DEGREES OUTSIDE... BBRRRRR COLD OUT.... AND IN THE DASH CAME WITH BIG RED COLOR IMAGE.. BATTERY LIGHT... NO CODES??? ANYONE RUN ACROSS THIS PROBLEM BEFORE. AM WORRING IF ITS THE ALTERNATOR...
armanix713 is offline
post #2 of 4 (permalink) Old 12-18-2009, 09:29 AM
Check Codes's Avatar
Vehicle: '01-E320 & 02-ST2
Quoted: 35 Post(s)
It's a decent worry, but I'd suggest posting down in the 211 forum rather than this general one...those guys have the same chassis as you and can give you more specific info.
Good luck and STAY WARM!!
Check Codes is offline
post #3 of 4 (permalink) Old 12-18-2009, 10:00 AM
Kajtek1's Avatar
Vehicle: E320/E250 Bluetec R129 SL500 - $1300 car ........ Ford F350 6.7l
Quoted: 1347 Post(s)
That most likely is the aux battery for the SBC brakes.
Check the manual to make sure.
To some degree low battery warning on cold start might be normal and if it goes away later I wouldn't worry about it immediately, but checking the prices in the mean time might be good idea. You will find several topics about it in W211 section.
Kajtek1 is online now
post #4 of 4 (permalink) Old 12-18-2009, 11:27 AM
Date registered: May 2005
Vehicle: '07 GL320CDI
Quoted: 2 Post(s)
If it's the original battery, it's old.
Starting always drains the battery a little and batteries in general lose voltage when cold. Yours would appear to be getting low and the start was enough to trigger the message.
It's highly unlikely it's the alternator and if you can run the car for a while and then restart it without getting the message again, it can be concluded the battery has been charged up by the alternator.
Kent Christensen
Albuquerque
'07 GL320CDI
lkchris is offline
Battery Light On: Changed Regulator + Battery... STILL ON! sightless R170 SLK-Class 7 06-25-2011 05:51 AM
battery light to srs light dim lit my90300E W124 E,CE,D,TD Class 9 01-15-2007 06:46 PM
Car dies every morning - even with a new Duralst Battery calhockey W203 C-Class 2 12-20-2006 08:17 PM
4k miles and this morning, the CHECK ENGINE light went on... elfkonig W163 M-Class 14 05-03-2003 12:07 AM
SLK 230 Battery not strong enough for a -24.5C start this morning.....(more) DanPro1 R170 SLK-Class 4 01-22-2003 05:01 PM
