CLK200K Error code P0410 - Mercedes-Benz Forum
post #1 of 1 (permalink) Old 12-18-2009, 07:47 AM Thread Starter
phooey's Avatar
Date registered: Dec 2009
Hi, i'm new to the forum and looking for some help with a secondary air injection error code on my 2000 CLK200K. I believe my car uses the Kompressor to inject the air into the cat via a vacuum valve and a check valve. I have checked the two valves and they appear to be ok. However I have found an issue with the change over valve which controls the vacuum valve. I have checked the voltage on the two pin connector from cold and the voltage on both pins do not change state suggesting I have a fault prior to the change over valve. Can anyone tell me where to check next? is the change over valve driven by a temperature sensor or is it the ECU? Sorry for the long thread but I am now at a loss!
Thanks in advance.
phooey is offline
    P0410 error code & CEL problem-- FIXED davyjo R129 SL-Class 27 05-31-2015 04:06 PM
    P0130/P0410 Error Codes jbond007 R170 SLK-Class 2 11-17-2009 04:16 PM
    Next steps in correcting P0410 error? ludoZici W163 M-Class 13 10-23-2009 01:56 PM
    P0410 Code solobinoy2k W203 C-Class 1 10-08-2008 12:42 AM
    code p0410 rbrandano W220 S-Class 1 08-31-2007 08:49 PM
