Pedal Sensor issues on w203 C200k - Page 2 - Mercedes-Benz Forum
post #11 of 14 (permalink) Old 01-24-2010, 01:38 PM
500SEC_AMG's Avatar
Date registered: Feb 2009
Vehicle: 500 SEC AMG Mod'd
Quoted: 5 Post(s)
Send a message via AIM to 500SEC_AMG
Originally Posted by Diesel Benz View Post
Yes, discussions often tend to find their way off topic, good to bring them back.
A pity the original poster did not get any response and no question for clarification. I wonder which diagnosis equipment gave as accurate a description as "a sensor". At least 500SEC_AMG could have his car diagnosed properly.
That's for the note DB, I have discovered that my issue is not RPM related because it doesn't hesitate when I down shift and it revs to 4000 rpm, it also won't shutter and sputter in Neutral... odd eh? Maybe it is shuttering but can only be noticed when engaged. $700 wild goose chase so far. The throttle value Sens makes sense to me. I will swap it with a new one and ask the garage to refund the MAF they installed as nothing has changed, when ever they reset the ECU I have 2 weeks of grace... then chug chug chug and heavy throttle
500 SEC Euro Classic White repaired!!
1987 Japanese 500 SEL Tri Ys and Velour
2000 CLK 430
Photojournalist
Collector of Vinyl
www.jakewright.ca
500SEC_AMG is offline
post #12 of 14 (permalink) Old 01-24-2010, 02:09 PM
keyhole's Avatar
Date registered: Sep 2006
Vehicle: 2004 CLK 240 Coupe
Quoted: 381 Post(s)
Originally Posted by 500SEC_AMG View Post
.... then chug chug chug and heavy throttle
If it does not ever splutter/hesitate when you rev in Neutral, I would not think that it is a pedal sensor problem. If your engine only goes bad under load, surely this points to something else?
keyhole is offline
post #13 of 14 (permalink) Old 01-27-2010, 06:17 AM Thread Starter
Date registered: Dec 2009
Throttle problem
Thanks for your input
I replaced the pedal frame including sensor
cost $400 Australian
problem now fixed
cheers
keithspinks
keithspinks is offline
post #14 of 14 (permalink) Old 01-27-2010, 09:04 AM
500SEC_AMG's Avatar
Quoted: 5 Post(s)
Well it turns out my ECU is not remembering its learned settings and not the Pedal value sensor. I might need a new ECU. So they reset all the sensors and throttle. Let's see how long that lasts
2000 CLK 430
Photojournalist
Collector of Vinyl
www.jakewright.ca
    W203 C200K Radiator fan run too slow nguyennhatquang W203 C-Class 3 01-14-2010 02:35 AM
    hesitation due to Throttle Position Sensor / Pedal Value Sensor patfarrell R129 SL-Class 37 10-04-2009 03:36 PM
    W203 C200K - Will Not start! JB1973 W203 C-Class 7 09-05-2009 03:34 PM
    Code 1542 (Pedal Value Sensor or Throttle Position Sensor) MDamg General Mercedes-Benz 1 02-24-2009 02:38 PM
    WTB: W203 C200K in Malaysia mynullvoid W203 C-Class 0 08-31-2008 04:00 AM
