clk 320 tip tronic intermitant fault - Mercedes-Benz Forum
post #1 of 6 (permalink) Old 12-16-2009, 09:53 AM Thread Starter
Date registered: Jul 2009
my 1999 12000 mile clk has just developed an intermitant gear change problem. when diving in s mode if im say doing 60mph and kick down or changes down on hill to 4 or 3 rd it wont change back up again just sticks in 3rd or 4 th till i stopthen wont go above 3rd gear althiugh still reads d on dash. also does the same if i change down manualy with tiptronic go back into drive reads d but wont change up. but then if i change from s into w mode on the move changes into top perfectly every time.. then next day is fine again also no problems at all if i drive in w mode all the time. really strange any ideas please.
ramsgate is offline
post #2 of 6 (permalink) Old 12-16-2009, 12:05 PM
keyhole's Avatar
Date registered: Sep 2006
Vehicle: 2004 CLK 240 Coupe
Quoted: 397 Post(s)
Originally Posted by ramsgate View Post
my 1999 12000 mile clk has just developed an intermitant gear change problem. .
Did you mean to type 120,000 miles? If so, have you ever had the ATF changed?
keyhole is offline
post #3 of 6 (permalink) Old 12-16-2009, 03:43 PM Thread Starter
yes i did mean 120000 sorry no not had atf changed since ive had it (20000) but cant understand why would work fine in w mode if that was the cause
ramsgate is offline
post #4 of 6 (permalink) Old 12-16-2009, 03:44 PM
Musikmann's Avatar
Quoted: 6 Post(s)
I would start by changing your transmission fluid and filter. If you're lucky, you have a torque converter drain and you can replace most of it. If not, replace as much as you can by dropping the pan and add back what you are able to drain from the pan. Wipe the pan out with a clean lint-free cloth to remove any gook and look for metal shavings. You might have to pour what you get through a strainer or cheese cloth. Be sure to use a MB compatble fluid for a 722.6 tranny.
Good luck.
Musikmann is offline
post #5 of 6 (permalink) Old 12-16-2009, 03:49 PM
Musikmann's Avatar
Quoted: 6 Post(s)
Only working properly in W mode is a bit of a mystery to me as well. That might mean there is something wrong electronically in the tranny or in it's control unit (TCU).
post #6 of 6 (permalink) Old 12-16-2009, 04:20 PM
keyhole's Avatar
Quoted: 397 Post(s)
Yes... and while the pan is off, the electrical connector seal can be checked for leakage.
keyhole is offline
    ML 320 ALARM FAULT. kingwinter W163 M-Class 3 07-06-2009 10:36 PM
    Pics with oval/CLK exhaust tip? NJBNZ W203 C-Class 20 04-09-2008 11:38 AM
    intermitant fault on 300sl 1989 lynne R/C107 SL/SLC Class 2 10-15-2006 05:37 AM
    Selling SLK 320 Tip/Auto (UK Based) - Autumn Bargain DaveMorton R170 SLK-Class 2 10-31-2005 12:28 PM
    Chrome exhaust tip for ML 320? ruperto W163 M-Class 3 07-17-2004 11:43 AM
