Aux fans not working 95 S320 W140 - Mercedes-Benz Forum
post #1 of 1 (permalink) Old 12-14-2009, 01:51 PM Thread Starter
Date registered: Apr 2009
My S320 temp has started to increase recently and I noticed the aux fans are not working even with the air con going. I pulled off the wiring connector to the condensor and the fans spun up briefly but stopped so I assume the fans work.
Can anyone help with this maybe it is a relay or temp switch I cannot locate the relays??
Also my soft close doors stopped working I pulled out the pump in the boot cleaned up to the contacts it worked again but stopped.
Everytime it stops working I pull off the wiring connector plug to the pump again and it works for another few days and I have to repeat this to make it work again...would this be the pump or another fault elsewhere? Thanks
CRPPRAT is offline
    Aux fans are working but only when ac is on not when the temp goes way up sycotik W202 C-Class 4 06-02-2009 03:37 PM
    overheating...aux fans not working... Eric W124 E,CE,D,TD Class 5 10-08-2006 02:39 PM
    Aux Fans not working... pic included of A/C Drier area '91 300CE W124 E,CE,D,TD Class 10 08-23-2006 08:13 AM
    Center two AC/heater fans not working while two fans on the sides are OK bespokeonly R129 SL-Class 4 11-05-2005 04:00 PM
    Aux fans not working! datchy W124 E,CE,D,TD Class 19 07-23-2004 08:16 AM
