Faulty Headligh switch E320 w210 - Mercedes-Benz Forum
post #1 of 1 (permalink) Old 12-11-2009, 08:48 PM Thread Starter
miglenda's Avatar
Date registered: Sep 2005
Vehicle: 1959 220 - 1961 220S - 1990 E2.6 - 1996 E320 - 2003 E320 / 1981 Pro Street Chevy P/up Org. 28,000KM
Question Faulty Headligh switch E320 w210
Hi... I have a '96 E320 W210 with Automatic DTR lights, and at the moment the right side marker, R/DTR light, rear tail light, including the R/brake light do not come on after starting the car.
I can get them ... The R/DTR ,R/side markers, including R/tailight to come on by turning the headlight switch to the 'parklight postion'. This is not a problem. Problem is that the R/ brake light, including the rear hat rack brake light also now do not work.
All fuses and bulbs are OK. and I am sure that the problem is in the ignition switch. Rather than spending $300.00 for the switch plus labour to re & re it, I have got the R/side markers, DTR light, including the tail lights to work as normal [ automatically] with out using the headlight control switch by running a jumper wire from the L/ rear tail light that works to the R/side that does not.
Does anyone know what part of the rear tail light 'mother board' is 'hot' for the brake light? I would like to run a jumper wire to the R/ side to make it work. I would just solder a wire to the correct position on the bulb holder and run the wire neatly out of sight. I have been trying different locations on the board for the brake light but keep blowing the fuse. Thanks in advance.
miglenda is offline
    Faulty brake switch?? Powder W163 M-Class 12 11-21-2011 03:29 AM
    Faulty Ignition Switch AlterMechaniker R129 SL-Class 13 04-19-2010 03:14 AM
    W168 faulty switch panel mgx W168 A-Class 3 12-28-2009 05:09 AM
    Faulty central locking switch?? Benzisgreat W124 E,CE,D,TD Class 10 01-15-2008 10:44 PM
    W210 E320 faulty starts when warm Renoir W210 E-Class 0 06-22-2007 03:46 AM
