HELP my mechanic - ML430 - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 12-11-2009, 07:20 AM Thread Starter
Date registered: Dec 2009
Me and my "mechanik" need yoururgent HELP !!!
I have ML 430 , year 2000.Here is the short story.The car at firs started to stall on the trafic ligt.After fiew cranks it started OK.Went to my mechanic,pluged the coputer and the code for crank sensor come up.Got the new crank sensor enthe car was ok.Two days later went to McDonalds park the car, got my food and the car din not want to start.It cranks but doesnt start..Call the tow truck and took it to my mechanic.Plug the coputer.. no codes..check fuel preasure 60 psi..spark comes to the plugs but the car is not starting( cranks.. but no start).Changed the plugs.After fiew cranks .. started .But the problem is steel there.Out of ten cranks .. starts 3-4 times..My mechanic is out of his mind.Hi said that could be some module at the egnition( key).This lasts for 5 days.No result yet.
HELP US please !!!
risto is offline
post #2 of 2 (permalink) Old 12-11-2009, 10:08 AM
leapyfish's Avatar
Date registered: Apr 2008
Vehicle: 1998 SLK230 199,xxx Miles
Quoted: 4 Post(s)
leapyfish is offline
    MB mechanic in NE PA Seville General Mercedes-Benz 1 06-05-2009 04:20 PM
    Need a mechanic danny redman General Mercedes-Benz 1 04-27-2006 03:55 AM
    Will 2001 Ml430 transmission work in a 2000 ml430? orlandotrader W163 M-Class 3 02-24-2006 04:31 AM
    mechanic? janos_z W126 S,SE,SEC,SEL,SD,SDL Class 0 11-03-2003 10:11 AM
    Mechanic in NW NJ Guest (MBNZ) Vintage Mercedes-Benz 1 06-14-2002 04:56 PM
