TD Sensor - Mercedes-Benz Forum
post #1 of 1 (permalink) Old 12-10-2009, 03:31 PM Thread Starter
Date registered: Nov 2009
Vehicle: 1988 190E 2.3
TD Signal
I have a 1988 190E 2.3 and the check engine light came on. The owner's manual said it was the O2 sensor. I changed it and tried to reset it at the diagnostic port, but there is no wire going to pin #5. I depressed the button for two seconds and released with the ignition key on and car off and the led light flashed 7 times. Is this the TD signal? If so, what is it? I read in other threads that it could be the engine temperature sensor (green with 2 prongs) or also the crankshaft position sensor. Please help.
ctdale is offline
    Hood opening and location of the CPS Sensor and Pre-Cat O2 sensor Check Codes W210 E-Class 55 06-22-2015 09:47 AM
    P0141 O2 Sensor Heater Circuit Malfunction (Bank 1 Sensor 2) GeoCrezz W210 E-Class 1 09-07-2009 07:08 AM
    check engine Cam sensor,knock sensor 1 and 5 cylinder misfire? kuku369 W210 E-Class 8 11-16-2008 06:25 PM
    Which O2 sensor? P0136 O2 Sensor Circuit Malfunction (Bank 1 Sensor 2) ClkE C208/A208 CLK-Class 3 05-16-2008 04:44 PM
    after installing new cats, 02 sensor heater circuit codes on both sensor 2s busoptr W163 M-Class 7 07-31-2007 12:18 AM
