Timing Chain - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 12-08-2009, 07:06 AM Thread Starter
Liz
Date registered: Apr 2009
Vehicle: 1997 400SE
Timing Chain
Had the 400se towed in yesterday - possible timing chain. What else should be repaired with the timing chain? Any suggestions for a place with good rebuilt parts in NJ?
Liz is offline
post #2 of 4 (permalink) Old 12-08-2009, 08:11 AM
keyhole's Avatar
Date registered: Sep 2006
Vehicle: 2004 CLK 240 Coupe
Quoted: 410 Post(s)
Originally Posted by Liz View Post
What else should be repaired with the timing chain? (
Impossible to say until it is examined in the workshop.
Is the W140 an 'interference' engine? If so, you might have done major damage to your engine. Damaged pistons, valves, cylinders, etc when the engine ran on with the timing out. Let's hope not.
Btw, what's the mileage? MB chains are pretty good, but normally let you know (by the noise) when they are on the way out.
keyhole is online now
post #3 of 4 (permalink) Old 12-08-2009, 08:18 AM Thread Starter
Liz
Vehicle: 1997 400SE
I'm at 175K - they are checking it out now - got it started but thinks it is flooded (fuel in cyclinders). Let's hope so
Liz is offline
post #4 of 4 (permalink) Old 12-10-2009, 03:01 PM
Date registered: Jan 2004
Quoted: 34 Post(s)
All Mercedes are interference engines.
Len
'59 220S Cabriolet - for sale - http://www.bruceadams190sl.com/1959-...20s-cabriolet/
'83 240D original owner 351,500 miles - sadly I let it go
'88 560SL 41,000 miles being parted out - https://sites.google.com/site/mercedesstuff/home
'99 E300 turbo 207,000 miles
'03 SLK320 37,500 miles
'14 Smart electric 10,500 miles
sokoloff is offline
Timing Chain Master Link - will Iwis work on the BECK ARNLEY CHAIN?? xxxbradxxx W123 E,CE,D,CD,TD,TE Class 8 10-17-2009 05:53 AM
Feeding in timing chain, attaching to old chain petecooke W123 E,CE,D,CD,TD,TE Class 4 09-18-2009 10:36 AM
IWIS timing chain compared to JWIS timing chain. ArkRoyal W126 S,SE,SEC,SEL,SD,SDL Class 5 07-01-2008 07:22 PM
Timing Chain or Timing Belt on 230 Kompressor ? Bal C208/A208 CLK-Class 0 11-21-2005 01:08 PM
Timing chain replacement/timing issue 1990 420SEL supersport6 W126 S,SE,SEC,SEL,SD,SDL Class 1 12-09-2003 02:03 PM
