ML320 cranking but not catching spark - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 12-07-2009, 06:12 PM Thread Starter
Date registered: Dec 2009
I have a 99 ML320 in very good condition and reluctant to just let it go, particularly since I invested a new trani about 2 years ago. Lately, the engine was trying to turn and I get cranking when I turn the key, but it wont catch a spark.
The battery is fairly new. As is the fuel pump and wires and plugs were done about 1 1/2 years ago.
I've gotten the run-around and thought I would ask those of you on this site. The indication, after much research, is that it could be the ignition coils. Has anyone else had a similar problem? How difficult are these to replace? Would have to replace all 6? I am assuming that the wire kit I had put in 16 months ago should still be good.
Any information you can give would be appreciated.
BillA10 is offline
post #2 of 4 (permalink) Old 12-07-2009, 06:23 PM
Check Codes's Avatar
Vehicle: '01-E320 & 02-ST2
Quoted: 35 Post(s)
Hi, Bill.
The first thing that comes to mind for me is the Crank Position Sensor. Fairly cheap and not an awful DIY. For six coils to go at once would be the height of bad luck, and the CPS is a common issue.
Welcome aboard and please take a minute to click user cp to add your vehicle and location to your profile as that is often useful information.
Check Codes is offline
post #3 of 4 (permalink) Old 12-07-2009, 06:44 PM Thread Starter
Thanks Greg.
The dealer sounded pretty-much "matter of fact". I wasnt buying in because they seem to be more interested in selling me a new car. I do know this... about 2 years ago, some moron changed the oil in it and did not put on the filter properly. Needless to say, the oil started squirting up onto the manifold and caught on fire. I pulled over immediately and fortunately happened to have the extinguisher from my boat in my car. This is about the only time I have ever had an extinguisher with me.
I did have some damage, and I replaced all the wires, plugs, etc. Is it possible that that could have made the coils brittle? If so, can this be determined by visually inspecting them? Are they easily accessible and easy to replace?
BillA10 is offline
post #4 of 4 (permalink) Old 12-08-2009, 07:39 PM
Date registered: Jun 2009
Crank sensor is a common problem. Also, there is a red light that flashes on the dash if it is a drive authorization problem. I forget exactly what the light does to tell you but maybe someone else will. Could need a key or the ring around the ignition switch. Try another key if you have one.
Pembroke36 is offline
    Which Spark Plugs for my 2000 ML320? agent-tom W163 M-Class 7 07-27-2009 03:46 PM
    ML320 spark plugs... Number400 W163 M-Class 11 06-29-2009 07:53 PM
    Ml320 Not Cranking Properly benzml320 W163 M-Class 2 02-21-2009 07:17 AM
    2000 ML320 Delay cranking.. hellah fresh W163 M-Class 15 08-28-2008 03:15 PM
    spark plugs: 99 ML320 mhinrichs W163 M-Class 0 12-13-2004 05:44 PM
