MERCEDES BENZ CLK 320 Coupe 1999 Need Radiator Fan Shroud+Fan Blade - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 12-07-2009, 01:28 PM Thread Starter
Date registered: Sep 2009
Do you guys know any website where I could buy fan shroud+fan blade for an affordable price. Do they sell it seperately or together? And also I found this website Genuine Mercedes Parts and it says that CLK 320 fan shroud is $150 and CLK 430 is $25. Do you know if those fan shrouds and blades are the same?
kri7ek is offline
post #2 of 3 (permalink) Old 12-07-2009, 03:53 PM
keyhole's Avatar
Date registered: Sep 2006
Vehicle: 2004 CLK 240 Coupe
Quoted: 384 Post(s)
Hi - please use the UserCP above ^^^^ to add your location/ride which often helps.
Regarding sources, I'm in UK so probably cannot help if you are in the US.
About compatibility, I believe that the two cars you listed do use the same part. See this drawing which details all the 209 engines that are applicable. CLK 320 uses a 112.9, and CLK 430 uses a 113.9
#1 fan shroud, #2 bolt, #3 fan wheel, #4 bolts, #5 bolts, #6 wiring
#M4/7 Engine & AC electric suction fan with integrated control.
keyhole is online now
post #3 of 3 (permalink) Old 12-07-2009, 04:01 PM
keyhole's Avatar
Quoted: 384 Post(s)
i have just noticed that you are talking about a 1999 CLK. That is a W208.
The info above is for W209 CLKs. So I am not sure if the information is still valid.
    V280 1999 Radiator Fan parm V-Class 0 08-09-2009 06:39 AM
    Radiator Fan blade hitting pulley dratner W201 190-Class 8 05-26-2009 04:34 PM
    W124 fan blade shroud throne7 W124 E,CE,D,TD Class 5 04-03-2009 01:25 PM
    WTB: Radiator Fan Shroud '97 E420 dsoutherland For Sale/Wanted/Trade/Giveaway 0 07-23-2007 11:38 AM
    Mercedes Benz fan blade f1crazydriver W126 S,SE,SEC,SEL,SD,SDL Class 4 07-08-2005 12:19 PM
