Front suspension problems - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 12-06-2009, 04:21 PM Thread Starter
Date registered: Dec 2009
Angry Front suspension problems
I own a 2003 E320 Sedan. At 55000 miles we had to replace sloppy lower ball joints. Now at 114000 miles, lower ball jouints are sloppy again along with the upper ball joints that are integral with the upper control arms, all require replacement to the tune of 1800 bucks. A couple of Mercedes mechanics have told me this unusual on Benzes with under 200000 miles. I suspect that these parts are undersize for the chassis that there on.Could there be a factory recall for this problem?
Rose P E320 is offline
post #2 of 3 (permalink) Old 12-06-2009, 05:42 PM
Musikmann's Avatar
Quoted: 5 Post(s)
You put a lot of miles on your car, more than average anyway. Who qouted you the $1800? If it was a dealer, that par for the course. If there is a factory recall, any franchised dealer should know about it. If yours doesn't, someone is not doing their job. Try a post on the W211 forum (what you have and under the sedans section) and you might get better info there.
Musikmann is offline
post #3 of 3 (permalink) Old 12-13-2009, 07:58 PM
Take your car to the mechanic. He can suggest better. All the best.
anthony.bill17 is offline
    Can you without problems change the V-class air suspension to spring suspension? kimberly V-Class 5 07-12-2010 03:30 PM
    HAVING MAJOR PROBLEMS WITH ABC AND FRONT END SUSPENSION, I NEED HELP!!!!!!!!!!!!!!!! shawnlr2822 C215 CL-Class 4 01-31-2008 08:32 PM
    Suspension Problems nhajari The Discount Tire Direct Tire, Wheel, Brake & Suspension 1 09-09-2003 01:44 PM
    2001 E320 front-right suspension problems Guest (MBNZ) W210 E-Class 3 06-17-2002 03:56 PM
    How much suspension travel is there on a SLK32 with OEM suspension; front & rear? Beng R170 SLK-Class 1 01-23-2002 09:33 PM
