Door Lock Pump/Door Close Pump Failure - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 12-05-2009, 09:12 PM Thread Starter
Date registered: Dec 2009
Unhappy Door Lock Pump/Door Close Pump Failure
I've put if off for long enough. I have a 1993 300SE i've owned since new, paid 70 plus thousand for it and do not want to give it up for pennies on the dollar. My door closing pump and my door lock pump have been out of service for too long. I've decided to fix the problem myself and did'nt want to pay the dealer thousands for this. My door locks don't work automatically and my doors don't suck in tight like the did. For starters I replaced the door lock pump under the seat thinking this will cure half my problem. I picked up the pump at a junkyard for $200 (numbers match exactly) a 140 800 0448. Plugged in the unit and all I hear is a very quiet air hissing sound coming from it when I unplug the 15 hoses. At first I heard nothing and thought I bought a bogus pump. Does this sound like a properly working pump? Does this thing produce vacuum or create pressure? Do my door locks need vacuum and pressure to work? My door locks still don't work. Just a big nothing but a slight hissing from the pump. Do I still need to replace the pump in the trunk to get it working? At first my doors stopped sucking tight but my door locks still worked. Now I have nothing.
fiwein is offline
post #2 of 4 (permalink) Old 12-05-2009, 09:19 PM
Administratoris Emeritus
GeeS's Avatar
Vehicle: 2021 SL770
Quoted: 544 Post(s)
Dunno what you have going on, but we have brand new door lock pumps (the one under the rear seat) for $375. The pump in the trunk is for sucking the doors shut, while the one under the seat does everything else.
GeeS is offline
post #3 of 4 (permalink) Old 12-06-2009, 04:54 AM
Date registered: Dec 2002
Vehicle: 92 500SEL to 01 E320T current 2014 lexus LS460
Peter Guenther is offline
post #4 of 4 (permalink) Old 12-06-2009, 05:54 AM
Musikmann's Avatar
Quoted: 5 Post(s)
Sounds like the junk yard pump is barely working and not producing the vacuum/pressure you need (yes they do both). I'd try to return it and buy the one from
Good luck.
Musikmann is offline
    WTB: Central lock pump & Close assist pump 4 1992 300sd Megadiesel For Sale/Wanted/Trade/Giveaway 0 02-12-2009 07:09 PM
    Unknown Door Lock Pump jhholl W140 S-Class 3 04-03-2007 08:02 AM
    DOOR LOCK PUMP jbleaux General Mercedes-Benz 2 09-05-2005 02:17 PM
    DOOR LOCK PUMP jbleaux For Sale/Wanted/Trade/Giveaway 0 09-04-2005 01:55 PM
    DOOR LOCK PUMP jbleaux W126 S,SE,SEC,SEL,SD,SDL Class 0 09-04-2005 01:49 PM
