worn crankshaft? - Mercedes-Benz Forum
post #1 of 6 (permalink) Old 11-29-2009, 12:10 AM Thread Starter
Date registered: Nov 2009
Unhappy worn crankshaft?
hi,i have owned my e320 cdi for 9 months.it had a minor oil leak when i purchased it(never required any top up in 9 months) but sent it to a local garage who diagnosed the crankshaft(front)oil seal needing replaced.while doing the work they discovered the crankshaft to be worn and advised me to sell the vehicle immediatley.the oil seal was replaced 4 weeks ago and i have used the car daily but now the minor oil leak has returned.is it possible to repair a worn crankshaft? i paid £2,500 for the car,is there a cost effective solution to this nightmare?? thanks in advance of any pointers.the car is a 1999 "v" reg and has 120,000 miles on the clock with sernice history to 79,000.
Last edited by ohlordwontyouhelpme; 11-29-2009 at 12:26 AM. Reason: year and mileage.
ohlordwontyouhelpme is offline
post #2 of 6 (permalink) Old 11-29-2009, 10:53 AM
Triggerhappy's Avatar
Vehicle: 1978 240D
Quoted: 41 Post(s)
Yes it is possible. But how on earth did the crankshaft get worn?
I would get a second opinion on that as it could be a $2000 fix. If that's the case it might be easier to replace the whole engine!
Triggerhappy is offline
post #3 of 6 (permalink) Old 11-29-2009, 11:06 AM
Date registered: Jul 2004
Quoted: 263 Post(s)
Sounds a bit shakey to me too. Did the shop in their next breath offer to take the car off your hands? I too would get a second opinion.
deanyel is online now
post #4 of 6 (permalink) Old 11-29-2009, 12:22 PM
flyboyike's Avatar
Date registered: May 2003
Vehicle: 2012 Focus SE
Quoted: 67 Post(s)
I find the idea that crank got "worn", but nothing else did especially suspect. The crankshaft itself is usually last to go, meaning, it would likely be preceded by rods and/or mains going tango uniform, but you haven't mentioned anything like that.
flyboyike is offline
post #5 of 6 (permalink) Old 11-29-2009, 12:44 PM
Kajtek1's Avatar
Quoted: 1064 Post(s)
The seal working in dirty environment wearing grove on the shaft is pretty common issue.
Years ago I had the issue on motorhome engine. Local part store had special thin sleeves that would go over the end of the shaft and gave positive fitting for the seal.
Sometimes the design gives you space to move the seal few mm, what will make it working on good part of the shaft.
Kajtek1 is online now
post #6 of 6 (permalink) Old 11-29-2009, 11:56 PM Thread Starter
thanks,i will get a second opinion.the garage didnt want to buy the car but offered me the chance to look for myself,however,i was a bit worse for wear from the night before.so declined.i have been told that the crankshaft could be "shaved" and a sleeve placed over it and "shaved" again to its original size.i think this would not be cost effective.thanks once more for your time.
    seats worn :( benzrider85 W140 S-Class 12 06-17-2008 07:02 AM
    Worn Key? tgoodwin W123 E,CE,D,CD,TD,TE Class 8 12-06-2007 01:37 PM
    worn out welcome Von Vorschlag Off-Topic 8 08-03-2007 08:07 PM
    Camshafts worn Rollingstone W126 S,SE,SEC,SEL,SD,SDL Class 19 08-23-2006 07:02 AM
    Worn out Key? MercedezGolf W126 S,SE,SEC,SEL,SD,SDL Class 21 02-11-2006 10:28 PM
