1989 420SEL High Idle and easily overheat - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 11-26-2009, 12:07 AM Thread Starter
Date registered: Nov 2009
Smile 1989 420SEL High Idle and easily overheat
just got this 420SEL.
the engine idles very very high rpm when the car starts then goes easily overheated at over 100 degrees within 3 min.
i can even drive the car at 45 mph without a foot on gas pedal. it just keeps on going until i brakes.
last night i was at Mcdonals drive thru waiting for the car in front for about 3 min, the car overheated and smog came out and had to get out of the drive thru abandoning my food and had to kept driving to cool down the engine, then the smogs gone and rpm returns to normal and temperature went back to normal.
this high idling is only happens when the car is in parking mode and revs up crazy like someone is stepping on the gas pedal constantly, but when the car drives out on the roads, the temperature backs down to low and rides so smooth and cool.
is there any way i can adjust or lower the engine idling myself?
time to time the idle resumes low when i put my foot on the brake pedal hard and put the gear into drive.
its very quiet and smooth car when driving..
irvineharley is offline
post #2 of 2 (permalink) Old 11-27-2009, 11:20 AM
Supporting Vendor
FCP Euro's Avatar
Date registered: Jul 2008
Quoted: 22 Post(s)
I would first check your throttle body and idle air controller motor. If they are dirty, give them a good cleaning.
Also, check for vacuum leaks, it sounds like you may have a big one.
Quality & Service, Guaranteed for Life
FCP Euro - OEM & Genuine European Auto Parts Online
FCP Euro is offline
    Hesitation/Stumble/High Idle W126 420SEL BenzFreak$$ W126 S,SE,SEC,SEL,SD,SDL Class 29 01-07-2013 03:38 PM
    Can 420sel engine be put into 1989 300se easily? spicyguy2005 W126 S,SE,SEC,SEL,SD,SDL Class 1 07-18-2009 05:55 PM
    87 420sel High idle and bad hesitation/stumble off idle. Please help! marzban123 W126 S,SE,SEC,SEL,SD,SDL Class 18 07-10-2009 01:42 AM
    High idle problem 1989 560sel 160,155 miles jdsilver560sel General Mercedes-Benz 0 06-11-2009 06:55 PM
    420sel with very high idle upon start. 1FastGT W126 S,SE,SEC,SEL,SD,SDL Class 7 03-10-2009 12:30 AM
