How do i replace window switch on 89 300E - Mercedes-Benz Forum
post #1 of 7 (permalink) Old 11-24-2009, 09:15 AM Thread Starter
Date registered: Aug 2009
I have a physically broken driver side window switch. How do I open the console to get at it?? Also, the window is 2/3 down, is there a way to bypass the switch to get it raised in the interim?
Thanks very much,
Jerry
jerryls is offline
post #2 of 7 (permalink) Old 11-24-2009, 10:27 AM
Musikmann's Avatar
Quoted: 6 Post(s)
That's a better question for the model-specific W124 forum. Scroll down from this general forum and have a look in the sedans section. Good luck.
Musikmann is offline
post #3 of 7 (permalink) Old 11-24-2009, 01:04 PM Thread Starter
thanks very much
I did a search but obviously in the wrong place!
jerryls is offline
post #4 of 7 (permalink) Old 01-06-2011, 01:41 PM
Date registered: Nov 2010
Did you get an answer to your question? Just asking because I need to do the same thing with an 89 300TE wagon and all the window switches are in the center console. I don't know how to remove what is needed from center console yet.
Thanks
Steve
Thanks very much,
Jerry
magentawave is offline
post #5 of 7 (permalink) Old 01-06-2011, 02:30 PM Thread Starter
Wow- that was a year and a half ago, and I'm not sure I recall all the details,but yes, it was easy to replace or swap. You pull out the little rug in the compartment behind the console and there is a screw to be removed. The switch is plugged into a socket with all the wires. Look at a used one for sale on ebay to see what it looks like unplugged. I hope this helps.
Good Luck
jerryls is offline
post #6 of 7 (permalink) Old 01-06-2011, 09:46 PM
So there is no need to pull out the ash tray too?
Thanks
Good Luck
post #7 of 7 (permalink) Old 01-07-2011, 04:37 AM Thread Starter
I don't recall exactly, but I may have loosened the front ashtry screws and just tilted it up from the back. There are lots of wires attached to the 4 switches etc, that will not allow you to raise it up very far.
jerryls is offline
    Help How do I replace the power window switch Steve1g R129 SL-Class 3 04-09-2011 02:00 PM
    How to replace a window switch? Hlstrdude08 W163 M-Class 4 05-01-2006 01:00 PM
    need to replace MAF and window switch... Christian1014 W163 M-Class 4 04-04-2005 06:56 PM
    Replace Window Motor and/or Switch? What Have I done?! mbz4sale W163 M-Class 2 10-05-2004 10:19 AM
    Help replace center console window switch craigbern W126 S,SE,SEC,SEL,SD,SDL Class 5 09-07-2004 06:47 AM
