new guy '86 300 SDL - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 11-23-2009, 01:24 PM Thread Starter
Date registered: Nov 2009
Vehicle: '86 300SDL
Send a message via Yahoo to -=DeanstuD=-
Arrow new guy '86 300 SDL
Hello, I am new to Mercedes Benz. I typed 300sdl into the search and read just about every post in anticipation of getting my car today.
My friend wanted a 'diesel' engine to put into his 1950 Ford F2. He found this car with a bad transmission and figured it might be a good donor.
After fiddling around and doing some research, we discovered that it was probably just the kick down switch keeping it in first gear. Apparently it was, because the trans seems to work fine now after mashing the throttle several times (engine off).
So, I drove the car, and really liked it. I thought it would be a shame to part such a nice car just for the engine, and so I traded him an '89 F30 that I was just going to part out anyway.
I have allot of receipts of work being done and just some of them include;
6/10/7 Fuel hose return line, in-tank hose, filter, screen
3/27/7 11" fuel level sender, 3 pos switch VJD1
2/11/7 6 injectors (NA 36x) OE Reman 6 heat shields (601-017-00-60)
312324 Oil PSI tube on turbo
310598 Head replaced
305253 Fuel shut off servo, 'mono' valve, Fan Clutch
302344 A/C condenser R-134a changeover, switch, relay, Cruise Control Amp, align"major service"
291494 trans overhaul/update, drive line disc @ trans, vacuum valve on injection pump
3/19/3 alternator
274840 Vacuum pump
268947 radiator, oil level sending unit
Anyway, that is my story, and here are some pictures. Nothing exciting, probably just looks like another old SDL but here they are;
Picasa Web Albums - -=DeanstuD=- - merc
-=DeanstuD=- is offline
post #2 of 2 (permalink) Old 11-23-2009, 08:59 PM
leapyfish's Avatar
Date registered: Apr 2008
Vehicle: 1998 SLK230 199,xxx Miles
Quoted: 4 Post(s)
leapyfish is offline
    What should I do with my 87 300 SDL? nbv4 W126 S,SE,SEC,SEL,SD,SDL Class 9 11-20-2008 09:06 AM
    87 300 sdl Gundog General Mercedes-Benz 0 01-12-2008 06:06 PM
    87 300 sdl FAULKER W126 S,SE,SEC,SEL,SD,SDL Class 1 09-06-2007 08:02 PM
    Model Year Picks for Mercedes 300 SDL/350 SDL Guest (MBNZ) W126 S,SE,SEC,SEL,SD,SDL Class 0 04-20-2001 03:34 PM
    Model Year Picks for Mercedes 300 SDL/350 SDL Guest (MBNZ) W126 S,SE,SEC,SEL,SD,SDL Class 0 04-20-2001 03:31 PM
