300D Transmission Rebuild - Mercedes-Benz Forum
post #1 of 5 (permalink) Old 11-20-2009, 03:13 PM Thread Starter
Date registered: Nov 2009
Vehicle: 1985 300DT
I came across a parts car, a 1983 300D in decent condition, runs great and no rust, but it has the dreaded transmission issue ---- it won't shift above 2nd gear (shift from 1st to 2nd, reverse is fine).
The shops are quoting me $2500 to $3200 for a full rebuild. From everything I've read and the folks I've talked to, that's a reasonable quote. And I know the main shop I spoke with to be reputable.
Just fishing for general ideas about other options, as in, are there any? Has anyone attempted a rebuild on their own, or does that require a prohibitive number of specialty tools? Is there any possibility that something less than a full rebuild might address the issue.
I'm not into the car for much, so I'll probably part it out, but thought I would throw the topic up on the Benz Board and see what people thought....
Thanks!
Chip-In-Austin is offline
post #2 of 5 (permalink) Old 11-20-2009, 05:06 PM
Kajtek1's Avatar
Vehicle: E320/E250 Bluetec R129 SL500 - $1300 car ........ Ford F350 6.7l
Quoted: 1342 Post(s)
Knowing the location would be helpful. In my area the car in working condition would be worth about the quoted transmission cost.
Are you getting the car for free?
Kajtek1 is offline
post #3 of 5 (permalink) Old 11-20-2009, 06:33 PM
Administratoris Emeritus
GeeS's Avatar
Vehicle: 2021 SL770
Quoted: 751 Post(s)
That is really a chunk of change. Might want to look into purchasing a reman unit and installing yourself.
GeeS is offline
post #4 of 5 (permalink) Old 11-21-2009, 10:38 AM Thread Starter
Vehicle: 1985 300DT
I'm in Austin, Texas. And yes, I got the car practically for free.
post #5 of 5 (permalink) Old 11-21-2009, 10:43 AM
Kajtek1's Avatar
If you get the car running it could be pretty rewarding, but paying the shop makes no economical sense.
I would search the net for rebuild, or running transmissions. If you can get one for few hundreds-you have good ride for less than a thousand.
Kajtek1 is offline
turbo rebuild for 96' 300D 05'DieselJunkie G-Class 5 03-30-2009 06:35 AM
FS Trans rebuild for 300d Wizz123 For Sale/Wanted/Trade/Giveaway 0 10-16-2007 08:52 PM
Transmission rebuild srsomasundaram W126 S,SE,SEC,SEL,SD,SDL Class 11 02-22-2007 08:59 PM
transmission rebuild snik W140 S-Class 0 06-14-2004 11:45 PM
Need rebuild transmission Guest (MBNZ) W140 S-Class 1 06-14-2002 02:46 PM
