Oil consumption question - Page 3 - Mercedes-Benz Forum
post #21 of 28 (permalink) Old 11-19-2009, 09:05 PM
e-420's Avatar
Date registered: Sep 2008
Vehicle: 1997 E-420 (150K miles), 1997 SL500, (90K miles) 2015 GMC Sierra Denali 2500HD CC/SB/4x4 Duramax
Quoted: 353 Post(s)
Originally Posted by surferrepoman View Post
Hello I am new to this forum. I have 06 E350 4matic with 74K. I purchused it with 54K one year ago. In the last 6 months or so it has been using 1 qt of oil every 1000 miles. I also have a noisey lifter. I drive 150 miles a day, all highway. I am using Mobil 1 synthetic. Any ideas or suggestions?
I find it interesting that virtually every mfg, including mercedes, considers oil consumption of less than 1 qt/600 miles "normal" for any warranty claim, when "typical" consumption is < 1qt/5000 miles or more. My e420 with 120K miles uses way less than <1qt in 7500 miles, and my silverado is the same wth 90K on it. My accord with 130K was about 1qt/3000 miles. So while you consumption is within the "normal" range it certainly isn't typical.
If your consumption went up suddenly I'd look for either a oil leak or something the the crankcase ventilation system plugged. The noisy lifter may be related to your problem.
By the way, I seldom put <20K miles/year on any cars I've owned, If you enjoy the car DRIVE IT! they aren't pieces of artwork for gods sake.
97 SL500 Imperial Red
/Parchment Leather/Black Top
Chromed OEM wheels, Akebono's, H1+90 fog, Burlwood/Leather shift knob, Rostra Lumbar support, Check seat heaters, Bilstein's, Parrot Bluetooth, GG Bailey Custom cargo mat, GG Bailey trunk mat, Real Burlwood Instrument Cluster w Chrome rings, Burlwood & Chrome shift surround, Euro headlights with Osram 70W/65W H-4's, clear corners, Silverstar corner lamps, Euro Trunk mount Warning triangle, SL600 Burlwood armrest trim & Burlwood cupholder sliding cover, Kahtec flashing third brake light (CHMSL)
97 E420 Royal Indigo/Grey Leather
Raintracker wiper, Rostra Lumbar support, Parrott Bluetooth, 17" chrome AMG replica wheels, Bilstein's, Akebono's, smoked marker lights, Osram 65W H7's, H1+90 fog, Rear Seat Child restraint Tether, Burlwood/Leather shift knob, OEM Mudflaps, DRL's, Becker Aux input
e-420 is offline
post #22 of 28 (permalink) Old 11-19-2009, 09:15 PM
Triggerhappy's Avatar
Date registered: Nov 2009
Vehicle: 1978 240D
Quoted: 41 Post(s)
I use Penzoil Platinum and I can go the full 5,000 miles between oil changes without losing hardly any. I have a C280 though so it may be different.
Triggerhappy is offline
post #23 of 28 (permalink) Old 11-20-2009, 11:55 AM
mergatroid's Avatar
Date registered: Sep 2009
Vehicle: 2010 E550
Originally Posted by Peter Guenther View Post
Both responses are stupid, I have a 01 E320 and with over 80,000 and 10,000 between changes it is never more than a half quart. I would see what MB has to say about it, or sell it.
......Regardless of the vehicle year----Good advice is"See a M.B. dealer"---If your dealer is not satisfying you,try another one ! They keep mine in top shape ! Very few mechanics can ,or will service a M.B. properly......and keep on driving it,if you can't drive it----what's it good for ?
mergatroid is offline
post #24 of 28 (permalink) Old 11-20-2009, 03:54 PM Thread Starter
Date registered: Jan 2009
Vehicle: 2006 E350 4matic
Thanks for all the advice and opinions. It is going to the dealer on Monday, they think the noisy lifter is caused by a broken tube or line that injects oil on the lifter. They want to open it up and check. There are no oil leaks, the engine is dry, and no smoke or excessive residue in tailpipes. I will keep you posted. Any other input would be appreciated.
surferrepoman is offline
post #25 of 28 (permalink) Old 02-10-2010, 09:41 AM
Cadore is offline
post #26 of 28 (permalink) Old 02-10-2010, 09:53 AM
Date registered: Feb 2010
Hey everyone, does anybody know what oil is used in a 2003 e55?
clola26 is offline
post #27 of 28 (permalink) Old 02-10-2010, 10:28 AM
Thanks everyone but my e55 is not burning oil irregularly its just down a quart and i just wanted to know if anybody knew what oil to use? Thanks..
clola26 is offline
post #28 of 28 (permalink) Old 02-10-2010, 10:39 AM
Kajtek1's Avatar
Quoted: 1070 Post(s)
There are links to MB oil approvals in stickies in W210 section.
I know owners of AMG models are too busy polishing their mufflers to worry about stuff like that.
So per latest publication the best oil for gas engine is Mobil1 0W-40, while for diesels it is Mobil1 ESP formula M mostly common in 5W-40.
Older manuals would list older generation of oils and should be ignored at present time.
Kajtek1 is offline
    Oil Consumption hooperdoski R230 SL-Class 24 01-15-2010 06:18 AM
    2003 C-Coupe oil consumption question hebertandre W203 C-Class 4 03-15-2007 03:46 PM
    Oil Consumption thread question bclark R171 SLK-Class 45 04-23-2006 09:45 PM
    Oil consumption question G-Benz230 R171 SLK-Class 13 04-03-2006 08:30 PM
    Oil Consumption kdedgley W126 S,SE,SEC,SEL,SD,SDL Class 12 01-19-2006 10:21 PM
