E class w211 instrument info display fault - Mercedes-Benz Forum
post #1 of 1 (permalink) Old 11-18-2009, 03:02 PM Thread Starter
smoothhound2000's Avatar
Date registered: Mar 2009
Cool E class w211 instrument info display fault
I have recently just gained a problem with my mercedes e220 model w211 55plate. The problem is with the instrument. The central circular information display and milage has become very bright. It should be black in colour with white info messages (trip, mpg, temp etc) but has now gone very light and the info is very hard to read as if to much voltage and is increasing the lcd image. When i first get in the vehicle in the morning it looks ok untill i start it up then in 5 mins its bright again. I have removed the display and reconnected it the day after but the same again. I have also tested the voltage when running and its ok around 14.3v I was wondering if there is a resistor of something in the display that is causing it or will i have to send this off for repair. I was a mastertech with saab and should understand most things you may suggest so any info would be great. Thanks
smoothhound2000 is offline
    E class w211 instrument info display fault smoothhound2000 Audio & Telematics Forum 0 11-18-2009 02:56 PM
    Instrument backlight fault darkside V-Class 6 05-18-2009 08:23 AM
    A140 Mileage Display Unit fault km2007 W168 A-Class 3 01-23-2009 02:02 AM
    A Class mileage / service display fault Reallyfedup W168 A-Class 4 03-23-2006 05:59 AM
    [BREAKING NEWS] Official info about the W211 E-class 4matic Drew W211 E-Class 0 08-04-2003 10:25 AM
