98 ML320 TRANS/DIFFERENTIAL PROBS? - Mercedes-Benz Forum
post #1 of 11 (permalink) Old 11-17-2009, 10:34 AM Thread Starter
Date registered: Nov 2009
I have a 98 ML320 with only 58K miles. I have developed some odd problems. Can anyone give me any suggestions. 1) Transmission occassionally will seem to start off in 4th or 5th gear from a dead stop, and will have a long shift between gears, but when I slip it over to tiptronic mode, everything seems to work fine. It only happens once in awhile, and does not seem to be "slipping". 2) I also am noticing noise in the rear of the vehicle upon turning hard into corners, similar to what a "locker" rear end would do, the "crabbing feeling" . Would appreciate any feedback.
benzo007 is offline
post #2 of 11 (permalink) Old 11-17-2009, 12:06 PM
Supporting Vendor
FCP Euro's Avatar
Date registered: Jul 2008
Quoted: 22 Post(s)
The first issue you mentioned could be an issue with the gear selection sensor.
As for the second issue, how old are your tires?
Quality & Service, Guaranteed for Life
FCP Euro - OEM & Genuine European Auto Parts Online
FCP Euro is offline
post #3 of 11 (permalink) Old 11-17-2009, 02:32 PM Thread Starter
98 ml 320
Not sure how old, they were on vehicle when purchased. Tires are approx. 65-70% tread depth of new. They are Goodyear Potenzas and have no uneven wear or cupping.
benzo007 is offline
post #4 of 11 (permalink) Old 11-17-2009, 02:39 PM
Musikmann's Avatar
Quoted: 6 Post(s)
OK, I think I know where FCPGroton is going with this. There is a date of manufacture stamped on the sidewall, you might check that. Tread depth is not the only consideration. The rubber could be deteriorating if they are close to 5 years old.
Musikmann is offline
post #5 of 11 (permalink) Old 11-17-2009, 02:53 PM Thread Starter
Don't see a date stamp. How would this effect differential in rear and not front ?
benzo007 is offline
post #6 of 11 (permalink) Old 11-17-2009, 02:57 PM
Musikmann's Avatar
Quoted: 6 Post(s)
Tire makers use a sort of code with (I think) day/month/year they were made but I don't remember the format. It should be on the outer sidewall unless yours are mounted so it's on the inside.
Your question is a good one so maybe you should have the rear differential fluid level checked and then possibly changed.
post #7 of 11 (permalink) Old 11-17-2009, 07:33 PM
Kajtek1's Avatar
Quoted: 1223 Post(s)
Find a "DOT" and than 4 digits behind it.
first 2 digits indicate the week and the following 2 digits year of tire production.
Kajtek1 is offline
post #8 of 11 (permalink) Old 11-18-2009, 08:50 AM Thread Starter
98 ml 320
There are several 4 digit letter/numbers. The only one I see that makes sense is a 0206 number, so I assume the tires were manufactured in second week of 2006 or something to that effect. So, I don't know if that would be old enough to warrant my problem. I am trying to pin down the noise I am hearing when I am making hard turns in either direction. It seems like a rubbing/rumbling sensation that is hard to tell if it is coming from the front or the rear of the vehicle. I have had other people listen and they think it is coming from the rear. It seems like the all-wheel drives should have some kind of crabbing when in hard turns on dry pavement, I may be wrong.
benzo007 is offline
post #9 of 11 (permalink) Old 11-18-2009, 09:00 AM
Kajtek1's Avatar
0206 is still pretty young tire. Unless you park on the sun a lot, you should still have few more years before any cracking or deterioration will show.
Intermediate noise on older car can be a nightmare. I learned to check if everything is right in the area and just live with it. It is quite possible that the noise just come from the tire.
Our ML320 come with original Generals and it took few years to wear them out and than find how much quieter Eagles are.
Kajtek1 is offline
post #10 of 11 (permalink) Old 11-19-2009, 01:58 PM
JaredMBClinic's Avatar
Date registered: Sep 2009
Vehicle: 1998 C240
[QUOTE=benzo007;3824571]I have a 98 ML320 with only 58K miles. I have developed some odd problems. Can anyone give me any suggestions. 1) Transmission occassionally will seem to start off in 4th or 5th gear from a dead stop, and will have a long shift between gears, but when I slip it over to tiptronic mode, everything seems to work fine. It only happens once in awhile, and does not seem to be "slipping". 2) I also am noticing noise in the rear of the vehicle upon turning hard into corners, similar to what a "locker" rear end would do, the "crabbing feeling" . Would appreciate any feedback.[/QUOT]
The earlier ML's make a lot of noise in the rear end while turning. Sounds almost like a grinding noise. Benz says get used to it.
JaredMBClinic is offline
    Blackstone Labs Engine, Trans, and Differential Oil Sample Results phate W203 C-Class 9 01-19-2009 12:27 PM
    Two Probs just Popped up Trans and Cruise mcbear W124 E,CE,D,TD Class 1 01-03-2006 01:06 PM
    Trans Probs RonJeffries R171 SLK-Class 3 10-07-2005 06:36 AM
    Comand 2.0 install probs ML320 2002 dnash Audio & Telematics Forum 4 09-27-2005 08:24 PM
    126 500SE auto trans and rear differential for sale grey500se W126 S,SE,SEC,SEL,SD,SDL Class 4 03-12-2003 03:15 PM
