1994 e320 spark plug problems - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 11-15-2009, 07:32 PM Thread Starter
Date registered: Nov 2009
I recently purchased a 1994 e320 with 150,000 miles on it that has a few quirks. The car was idling rough when I first saw it, but for $1800, I thought it could be worth fixing. Anyway, today I discovered that 2 of the spark plugs had shattered ceramic and when I pulled them they were blackened as well. I successfully replaced 5 of these NGK plugs and installed Bosch +4. The 6th plug has been a bit of a problem for me because the plug separated at the threads. The entire ceramic portion of the plug, along with the nut end that the socket fits onto, slipped right out of the threads. I am using a screw removal kit to try and get it out of there to no avail. I am starting to think that the spark plug threads might be fused into the aluminum cylinder head. I am not sure what to do next, because I was so close to solving this problem. I know I should probably remove the head and have a machine shop heli-coil it, but i want a quick fix that won't score the cylinder walls. Any advice would be appreciated.
jlmichael is offline
post #2 of 2 (permalink) Old 11-17-2009, 10:16 AM
Date registered: Dec 2008
Vehicle: w204 (C350ELE)
Have you heated it? If you're going to try it, stick the removal pin ready to turn with the plug. Heat the thread area (the aluminum will expand more than the steel) and turn the pin. Better yet, tap if you can for a left thread screw (if you can get screw and tap) and drive the screw, then apply heat, then try to turn the screw and drive the plug out.
Watch out with making a pyre, keep the heat localized, on dry and fuel-free surface. A low power electric soldering gun may be best.
JoeVal is offline
    1994 E320 freeze plug leaking - help NitroTrike W124 E,CE,D,TD Class 19 03-28-2010 04:17 PM
    E320 Spark Plug Diagram taberd1975 W210 E-Class 11 06-06-2009 08:57 AM
    Spark Plug Gap for 1994 e320 swanny2070 W124 E,CE,D,TD Class 3 05-06-2008 02:25 PM
    Spark Plug Change E320? justo W210 E-Class 5 09-13-2007 10:46 PM
    Spark Plug torque '98 E320 rydin W210 E-Class 1 05-13-2006 05:51 PM
