Abnormal noise - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 11-12-2009, 09:58 AM Thread Starter
Date registered: Nov 2009
Abnormal noise
i recently brought a 2006 C230 from an private dealer. The car still has a original warranty left on it.
When I start my car in morning, there is high pitched screeching sound come from the hood and goes away in couple of minutes. Is it the fan?? Will it be covered under factory warranty??
I've noticed a lot brake dust on the front two wheels only. The dealer had replaced the old brakes. Is the dust normal. There is no significant dust on the rear wheels.
Thanks advance for your help.
John_Dazzling is offline
post #2 of 2 (permalink) Old 11-12-2009, 03:44 PM
leapyfish's Avatar
Date registered: Apr 2008
Vehicle: 1998 SLK230 210,xxx Miles
Quoted: 5 Post(s)
Welcome to the forum http://www.benzworld.org/forums/
The brake dust is normal for stock pads.
Please post your question in the model specific area, in your case W203 C-Class - Benzworld.org - Mercedes-Benz Discussion Forum some one there should have an answer regarding your problem.
leapyfish is offline
    ETS light on , abnormal sound. bondale W210 E-Class 3 11-17-2006 04:29 PM
    2000 ML430 Abnormal Engine Noise ... dt77 W163 M-Class 14 01-20-2006 11:21 AM
    Abnormal movement in driver window JoeBlow W163 M-Class 2 10-24-2005 10:40 AM
    see if you can find abnormal with picture. angldrkns9 W163 M-Class 12 12-22-2003 04:10 PM
    Help, abnormal tire wear... nicecar R170 SLK-Class 12 03-04-2003 11:33 AM
