1998 Mercedes S320 - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 11-08-2009, 03:11 AM Thread Starter
Date registered: Nov 2009
1998 Mercedes S320
Sorry if im posting inthe wrong place Im new to this site and so far I love it really good info I have been reading for a couple of hour and now this my problem..I got a a 1998 S320 with 143,000 miles the car was working fine until couple of days started by going into limp mode dont knwo what gear but by simply reseting (on/off) the car it will work fine until today on/of wont work no more is limp mode I got reverse but when I change from P to R OR D the tranny will jump or pull is sound loud not to much but enought to notice that is not normal.. The check engine light,
I am getting an ODBII Error - "P0743 Torque Converter Clutch Circuit Electrical" nothing else.. also I check the transmision base on the reading I did here for leaks and I can see some leaks the connector is full of oil.
I have erase the code with the OBD but after having the motor running for sometime the code will come back.....
My question the sensor lacation is inside the trany ?
meaning that the transmission needs to be remove or is unde the oil pan ?
or do i need a new transmission.... thanks in advance
tiburondkb is offline
post #2 of 3 (permalink) Old 11-08-2009, 09:59 AM
Musikmann's Avatar
Quoted: 5 Post(s)
Maybe someone here can help you but you have a W140 and there is a forum devoted to those. It is located under the sedans section. Good luck and welcome to the forum.
Musikmann is offline
post #3 of 3 (permalink) Old 11-08-2009, 11:34 AM Thread Starter
    Keyless Problems w/S320 1998 W140_S320_1998 W140 S-Class 30 07-04-2009 10:14 PM
    I need a tan console for 1998 S320 salmaqtari For Sale/Wanted/Trade/Giveaway 2 04-18-2008 12:01 AM
    FS- 1998 S320 Parts s32098 For Sale/Wanted/Trade/Giveaway 0 07-05-2006 11:43 AM
    FS: 1998 S320 LWB, So. Cal. s32098 For Sale/Wanted/Trade/Giveaway 10 03-18-2006 05:09 AM
    1998 S320 A/C Problem s32098 W140 S-Class 6 07-23-2004 10:30 AM
